tbi idle
Old Aug 23, 2004 | 12:17 PM
blackrock68's Avatar
tbi idle
I replaced my battery on my 1988 tbi 305 transam. now the idle is like 200rpm higher than before.Is there a procedure to set it?
Old Aug 23, 2004 | 01:26 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
The idle is non-adjustable. If your voltage was really low due to a bad battery and non-functioning alternator then there is the possibility that the IAC was disabled. How high was it before?
Old Aug 23, 2004 | 02:01 PM
tbi idle
600rpm
Old Aug 23, 2004 | 02:34 PM
90FormulaWS6's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
Transmission: WCT5
on my TBI i have an idle adjustment... i poped off a little cap and behind it was a hex head screw that i could adjust my idle with
Old Aug 23, 2004 | 03:11 PM
Car: 88 Camaro SC
Engine: SFI'd 350
Re: tbi idle
Originally posted by blackrock68
600rpm
thats where its supposed to be.
That scew is for the min idle adjsutment. Opening it more will just cause the ecm to command fewer IAC counts. Not necesarily a bad thing but none the less itll still idle the same as long as the iac counts are >0
Old Aug 23, 2004 | 08:13 PM
FirebirdBrtha90's Avatar
From: Somewhere just below the Mason/Dixon Line, MD
Engine: 383 stroker in the works
Can anyone give me suggestions about why my '90 TBI Formula idles rough at only 500 rpm? Tune up was performed lest than 3k miles ago. Any help would be greatly appreciated.
92camaroJoe
Jul 29, 2023 07:57 PM
MustangBeater20
Oct 29, 2022 09:20 PM
db057
Sep 4, 2015 07:57 AM
92camaroJoe
Aug 13, 2015 06:07 AM
