TBI help please
Car: 1986 Vert Z28
Engine: SuperCharged 350
Transmission: 5 Speed Manual
TBI help please
Friend of mine has the same 91 RS convertible camaro as mine, And he had it sitting in the back yard for 3 years while he was in japan. We towed it out into the garage and did a full down maintenance on everything (oil, plugs, wires, tranny filter, fuel filter, etc)
Trying to turn the car over, it 'puffs' every once in a while but won't start. Started once for 3 seconds but w/ full throttle and ran horrible and rough. Trying spraying in carb cleaner to start, and it didn't make a difference.....
Anyone got any tips for bringing the beast back to life? Somthing that i should be looking for?
PS- Fuel pump works. And how common is it for a ECM to go out?
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Did you test the fuel pump to make sure ot was okay. You should be seeing 9 to 12 psi in the feed line. Anything below that will not suffice. Even though you may see fuel come out of the injectors, it won't be enough. I would also put in some fresh gas. 3 year old gas that has sit outside isn't always the prime solution for optimun running conditions.
Car: 1986 Vert Z28
yea, Tripple checked it against the book.
also, we turned the engine over a few times before we got it to the garage, and it was acting the same way before too. and it was running fine the last time it was ran before that.
Car: 91 RS
Engine: 350tpi comming soon!
Transmission: fixed the 700r4 again!
im sure the gas has alot to do with it. my car sat for like 8 months in my garage while i fixed tranny problems but when i got it started it ran pretty bad until i got a full tank of good gas in it and that was just after 8 months not 3 yrs. even after you get it started its gonna run bad for a bit . once its half way rinng good, take it out to a place you can consistantly run it at liek 65 or so . that will help too once the car is started.
good luck
good luck
Car: 1991 Chevy Camaro
Engine: 305 TBI
How's the battery?
EDIT: Sorry. I mean, what's the condition of the battery? How old is it, do you know how many volts it's holding (it should be around 12 with the engine off), etc.?
Car: 1986 Vert Z28
Battery isn't great, but w/ a charger we can get it to turn over pretty well... it just isn't charged. (probably is charged by now though)
Car: '90 RS
Engine: 377 LSX
You may also want to check all of your wiring. Rodents tend to move in over long storage periods and they gan eat up all sorts of wiring.
Engine: 305TBI
Axle/Gears: B&W 9 Bolt 3.73
good luck
good luck
Car: 1986 Vert Z28
Yea, i know all about the rodents... My first camaro i baught was a 85 Iroc "uned Port" (the "T" had broken off...lol) and i had to wire splice -EVERY- wire comming out of the fire wall. that was not fun.
Anyways, it doesn't look like wire damage.
I've been doing alot of searches and heard somthing like the Cam might be turned 180*, so that the spark plug wires needs shifted over 4 places on the distributor. I don't know how commen or possible that is, sounds plausible to me. but it's easy to check so were going to try that, along checking that all the pushers are pushing, and all the rockers are rocking
Car: 1986 Vert Z28
Well, We Tripple checked all the plugs and wires and such and after a few more trys it started turning over... Now, i'm not 100% sure if it was somthing as stupid as a bad plug, but i'm thinking after turning it over so much that the good gas finally started getting pushed through.
So yea, it's running, not great though. Were giving up at this point, and just bringing it to a mechanic we know real well. hate to do it, but we don't know what else to do.
Thanks for Everyones Help!!! :lala:
Car: An Ol Buick
Engine: Vsick
How to go from square one, and get an engine to start.
http://www.t6p.com/forums/showthread.php?t=3626
rs_z28_vert
Sep 30, 2015 09:47 PM
