ECM question
Old Aug 25, 2004 | 04:03 PM
kingsizeguitar's Avatar
ECM question
I'm trying to hunt down a starting problem and am looking to check to see if i'm having a crank signal. I want to pull off the ECM harness and check the pin that should be carrying the signal, only I dont know what pin it is. Anybody have a wiring diagram they could check or know where i should be looking? Thanks.
btw, just to make things easier, where is the ECM located? I'm assuming somewhere around the instrument cluster but i'm not quite sure.
Old Aug 25, 2004 | 07:53 PM
iggy1991's Avatar
Car: Red 91 RS Camaro
Engine: LO3 with Comp Cam
Axle/Gears: 4th gen rear
Its under the passenger side right under the plastic panel in the foot well. As for the wire that carries teh signal I have no clue.
Old Aug 25, 2004 | 09:45 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Have you checked to see if the injectors are spraying any fuel while cranking? Also, you may want to get some sort of scantool to see whats going on.
Old Aug 26, 2004 | 03:56 PM
Well there's no spray while cranking, I know a pretty good mechanic who said he's going to look in some manuals and try to give me a hand with it.
ezobens
Aug 19, 2015 10:29 PM
355tpipickup
Aug 19, 2015 10:02 PM
redmaroz
Aug 16, 2015 11:40 PM
djmarch
Aug 10, 2015 08:42 AM
