wont ideal cold & smokes warm HELP
Old Sep 2, 2004 | 10:54 PM
yesme2y's Avatar
Car: 4 camaro's & a duramax & B deere's
Engine: 305 lt1 454 350 & 2 cyl.
Transmission: auto's & 1 4 gear & 6high low
heres the run down.... 1989 305 tbi auto convertible
this car needs a mircale & should have been put out of misery instead of me trying to resurrect it
First off when i got car it didnt run told it was sitting last 10 yrs & fuel pump was out ? well i started with a new fuel pump didnt need it it was hose off fuel pump in tank (fixed that ) then needed a key so got that. now it ran fine last yr. kinda but this yr it wont start easy & when it does it wants to kill, but once it warms up it ideals just fine, & starts fine but does not smoke cold but when warm it starts to smoke
i tried map sensor & cold switch on front intake manfold didnt help at all dont know what else ? no check eng lights come on at all all it does is hard to start rugh running till warm then smokes so help before i shoot it & park in my parts car line
Old Sep 2, 2004 | 11:08 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I geuss we need a little more info on the car. What is its state of tune? How mnay miles are on the car? Did you run a compression check? It sounds like you may have some serious problem if it is blowing smoke when at opperating temps.
Old Sep 2, 2004 | 11:38 PM
yesme2y's Avatar
state as in nebraska or state as in it runs smooth..... car shows 67000 miles dont know if thats 167 or just 67 i got car from old person who took it from there kid who destroyed it...& he didnt know much other than it should be a parts car but i couldnt do that at the time never ran a compr. check it runs smooth doesnt always smoke just most of the times i should have said. didnt use no oil last yr when i drove it till winter
Old Sep 2, 2004 | 11:42 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
State as in condition or status. I geuss I am not sure what the problem is. Is it just hard to start when cold? Do you turn the key (not enough to crank) and puase and let the injectors prime? That may help.
Old Sep 2, 2004 | 11:54 PM
yesme2y's Avatar
no not the inj needs prime its when its running on cold start it runs very rugh hard to keep running was told fuel problem but ?? but when it warms up it runs out smooth like new other than smokes
Old Sep 2, 2004 | 11:57 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Well it could be a million things. Has the car had a tune up? Bad or worn out ignition parts can cause cruddy running when the engine is cold.
92firebirdguy
Sep 1, 2016 07:53 AM
Grant2k
Apr 4, 2016 08:21 AM
L98GTA87
Oct 19, 2015 10:43 PM
KCG
Sep 23, 2015 09:05 AM
Accerrito22
Sep 5, 2015 09:34 PM
