Quick intake swap question...
Old Sep 6, 2004 | 11:07 AM
BadBlue91RS's Avatar
Car: 1991 Camaro RS
Engine: Briggs & Straton
Transmission: Centrifical Clutch
If I were to just slap this Torquer II on my car without any chip modification...how badly would it affect drivability? Would it be worth doing right now, or should I wait till I can get the chip worked at the same time? I don't really see an intake swap doing all that much to need drastic chip work...but hey, what the hell do I know
Old Sep 6, 2004 | 05:23 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Youll probably need more AE since there will be more plenum volume with the shared plenum. The real issue is that it may be a bit of a mismatch for your L03. A good dual plane would be better, although I wouldnt use any 'airgap' type designs. The tune is set up for a fully heated manifold.
Jorlain
Aug 24, 2022 05:11 PM
midge54
Jan 29, 2017 07:00 PM
theurge
Aug 21, 2015 12:46 PM
happyhapka
Aug 15, 2015 04:42 PM
