Closed Loop, EGR, Thermostat Temp?
Old Sep 6, 2004 | 11:22 AM
1993GMCPU's Avatar
Car: TBI CHEVY, TPI 5.0 HO
Engine: 5.7 FIRST hp SMALL BLOCK, BIG BLOCKS!
Can you run a little cooler thermostat without hurting a 93 350 GMC pickup from going into close loop? They come with a 195 and thought maybe I could run a 180 or is that not something I should do? Asking because after going through problems with fuel pump and fuel pump sending unit, I get a good start, good voltage to pump and all things seem great. I get a slight back fire now and then when I put my foot in it, but I get no codes. We wondered if it was going into close loop or not and if there was a way to tell? EGR was blocked when 3704 Edelbrock manifold was installed, but again, we get no codes at all! Any ideas or suggestions welcomed.
Old Sep 6, 2004 | 05:16 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
180 will be fine if you want a little cooler operating temp.
Old Sep 6, 2004 | 06:43 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Put in a 180 in my 91 Pickup, works fine but I do get a slightly higher idle when it runs at thermostat temp.
Old Sep 6, 2004 | 08:27 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
180 is fine. I would start with the basics since you did an intake swap. I assume you set the timing correctly?
Old Sep 7, 2004 | 09:44 PM
1993GMCPU's Avatar
I have about 8 degrees advance using Proform Distributor as recommended by Comp Cam 8-10 degrees. 10, well motor wanted to start to surge a little, but it's ok at 8 and seems to want to run strong.
Bubbajones_ya
Jul 6, 2024 08:32 PM
86IROC112
Sep 11, 2015 04:04 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
rjcme
Sep 5, 2015 01:23 PM
85Special
Sep 3, 2015 04:21 PM
