No Spark
Old Sep 17, 2004 | 06:16 PM
DA 89 CAMARO's Avatar
Car: 89 RS,97 Z28
Engine: 305 T.B.I,350 LT1
Transmission: T5,T56
No Spark
i was drivingmade a right turn the car backfired! something that had never happen before then just died.ende pushing the car home .good thing i was around the corner.now im getting no spark.changed the rotor,distributor cap,still no spark can anybody help
Old Sep 17, 2004 | 09:12 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
The rotor and dist. cap have little to do with the car not having spark unless theyre damaged. It could be alot of things. Faulty coil, loss of power to the distributer and coil, bad module.
Before replacing anything more, check all the connections, plug and coil wires, and grounds to make sure there arnt any loose connectors or wires. Also check to make sure the distributer and coil have power in the right places. If your in a pinch and you need wiring diagrams, the chiltons manual has reprints of the factory f-body wiring manual. Not in color but theyll do.
Old Sep 19, 2004 | 02:50 PM
Car: 89 RS,97 Z28
i checked all connections from starter to battery to distributor they all seem ok everything looks ok.i got new spark plug wires and battery just to eliminate that and it still doesn't want to start.somebody told me about a relay on the firewall on the driver's side and it did lok kind of mesed up.i picked up a couple from junk yard they are not an exact match but i used three to make one but nothing .i think it'sa the coil but i don't want to spend on stuff i don't need.can somebody offer suggestions
Old Sep 19, 2004 | 11:16 PM
Car: 88 Camaro SC
Engine: SFI'd 350
After youve made sure you have power in the right places at teh dist. and the coil you can start checking things.
The first thing would be to check if it has a weak spark or no spark at all. Remove one sparkplug and plug the wire back on the plug. With the fuel injectors disconnected, hold the spark plug up against the cylinder head and have someone crank the motor over. It should give strong, blue-white sparks. Anything less like weak orangy-blue sparks is basically no spark at all. Be careful, though. Try to keep your hand as far away from the spark plug as possible. The coil can pack quite a punch. I think spark testers are available but I dont own one.
The module is a possibility. The module is relatively easy to remove so you can take it down to an autoparts store to have it tested. If it is bad then getting a new GM module would be advisable. I never thought much of the cheap stuff from the autoparts stores.
Another possibility is a faulty or disconnected pickup coil. As for the ignition coil, it could be bad as well.
On top of this, it could be a general no-start problem if you have yet to deterimine that you have no spark at all.
The chiltons manual as well as a reprinted factory manual will have flowcharts, diagnostic procedures and wiring diagrams in them. Picking up a good manual would really help you diagnose your problem.
Old Sep 21, 2004 | 09:52 PM
Car: 89 RS,97 Z28
I wound up taking thec starter out to get it tested and now i need a new starter. i hope that's it
Old Sep 21, 2004 | 11:26 PM
Car: 88 Camaro SC
Engine: SFI'd 350
Jsut about every thirdgen needs a new starter if it has the origional. Itll turn over a lot faster but its unlikely that the starter will cause your cranks but doesnt start issue.
If it had a didnt start because it didnt crank then I think youve found your problem
Old Sep 22, 2004 | 05:00 AM
90RS305's Avatar
Car: 96 Silverado/99 Suburban
Engine: 700 cubic inches of 'Muican Awesome
Transmission: 4L80/4L60
Axle/Gears: Chunky/Clunky
Originally posted by dimented24x7
...If it had a didnt start because it didnt crank then I think youve found your problem
lmao! Anywho, make sure you check your ignition module. Those things can go bad and you'd never know it. I replaced my cap/rotor, coil, AND plugs before I figured out what it was. It's the little (almost U shaped) dohicky right under the cap. has 2 connections coming from it, one going to your coil. $30 from AutoZone with a lifetime warranty...
Bruce (90RS305)
Old Sep 28, 2004 | 03:26 PM
Car: 89 RS,97 Z28
just put on the starter just like i thought it still doesn't start.i guess it's on to the ignition module.auto zone here i come
Old Sep 28, 2004 | 07:18 PM
Car: 89 RS,97 Z28
hey! thanx that was it saved me some money too now i just got to worry about the black and white smoke coming out of the exahaust thanks again!
Old Sep 28, 2004 | 08:40 PM
90RS305's Avatar
No prob Thats what I figured it was. To my understanding it isn't uncommon for that thing to fail...
RedLeader289
May 28, 2019 01:47 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
HoosierinWA
Oct 7, 2015 10:15 AM
meeklay812
Oct 1, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
