What should I do ???????
Hi I just bought a 1988 305 TBI 5 speed manual IROC. I have already had to change the fuel pump. That did not fix the problem it still idle real fuuny. Like it idles at about 15 then it drops down to 10 then 6 then it cuts off and it won't start for like 20 or 30 min. What is normal idle? Where should the oil guage be at normal operating temp. What is normal operating temp. The car smoke on start up and it is leaking oil from the bottom somewhere. I am thinking about get a the engine rebuilt or overhauled. A friend of mine said that I should wait get a few preformance part have them put in while the motor is out because it would not make sence to open the motor change the seals and gasket he said it would be just as much to have them put in the parts while the motor was open. Remember this car is a daily driver and I am not really in to performance as much as I really want a car that will start all the time and want stop halfway to where i am tryin to go
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Welcome to the boards. What is the state of tune of the car? Meaning, how many miles does it have and has it at least had a full tune-up or two somewhere in its lifetime. A bad 02 could cause your problem along with a bad CTS. I would find out where the oil is leaking from. It could be the rear of the intake manifold, valve covers, or the rear main seal. Smoke on start-up is typically worn valve seals. If your car still smokes after it is warmed up it could be much worse. normal operating temp is 195* (assuming you have a stock rated thermostat). However, the temp will rise until the fan kicks in and and vrongs it back down. This is normal.
Car: '90 RS
Engine: 377 LSX
Originally posted by tb8125
the car has 130,000 mile on it looks like it has had at least one tune up because the wires are not in the litte barckets they are zip tied up
