one injector not working on holley tbi
Car: 91 Camaro RS 383
Engine: carbed 383
Axle/Gears: 3.42 posi
OK i know its not about my camaro but it has to do with my K5 Blazer and my new holley tbi. First of all i didnt get the pigtail for the injectors so i cut and spliced it all in. The problem is that my pass side injector does nothing at all. I dont know if it has to do with the connection on the cap and the little prongs or what.. I tried switching plugs for the diff sides and the pass side still didnt work so i think it mat actually be the injector??? Any help is appreciated
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Its a strong possibility that it may be the injector. What resistance do you get from it? From the sound of it the injectors are those old style ones so swapping a stock pod on might be a good idea.
Car: 1990 Formula
Engine: 355
Probally th einjector, I have had two of mine go out. A tip, if you go to a parts store you can get a replacement injector at autozone or such if you ask for a 88 dodge Dakota, V8 injector. th eholley utilizes Mopar injection.
Car: 92 Z28
Engine: 305 TPI, Edelbrock headers, 3in Flowmaster exhaust
I had the same problem on a crossfire TBI Z28. After trying a different injector, checking fuses and everything else, it turned out my cars computer was the problem. I repaced it with a new one and everything was fine.
Engine: carbed 383
Well i just went outside and switched wires from the diff injectors and my wiring is fine because the pass side still wont work. This is a new throttle body but i think i have the old style injectors(half sphere black cap) I dont want to swith pods because my other injectors are shot and they look different anyways. How can i get this injector out??
THANKS
THANKS
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
THANKS
THANKS
Engine: carbed 383
the holley unit looks to be sealed so im sending it back to where i bought it so they can put a new injector in. Thanks for all the comments
Car: 88 Camaro SC
Engine: SFI'd 350
You should ditch that thing and use your stock pod with some good injectors on the holley base. Those ones in there now are nothing but trouble.
9192camaro
16
Feb 3, 2019 12:21 AM
