Another Manifold
Old Sep 28, 2004 | 05:20 AM
va454ss's Avatar
Car: 90 454SS
Engine: 454 TBI
Transmission: TH400
Another Manifold
I've recently sealed the deal on a used Edel MPFI conversion system.
Anyway, I will be evaluating the manifold as a wet flow unit with my current TBI.
Also, I may eventually use the complete system as a supplemental fuel supply for when I install the Vortech
Old Sep 28, 2004 | 12:43 PM
BronYrAur's Avatar
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
Awesome. I'll be interested to see how that manifold works out for you. Do you know if the design of the manifolds for big block and small block are the same or similar?
Old Sep 28, 2004 | 02:52 PM
va454ss's Avatar
Car: 90 454SS
Engine: 454 TBI
Transmission: TH400
Just from the pictures I've seen, they are similar.
A very reputable engine builder believes it will work well in a wet flow application.
I was going to research if the manifold was available separately from Edelbrock, but this deal fell in my lap, so I didn't pursue it.
It would really suck to find out it is an awesome manifold for TBI wet flow and the manifold not be available separately.
From what I've seen, its basically just a single plane with a small plenum.
At any rate, I'll do a comparo after I complete the eval of my current single plane.
If Edelbrock follows in Vortech's footsteps, they may stop manufacturing the system and let them go for cheap. (Vortech recently discontinued their system for the 7.4 TBI)
I also lucked out as the kit I'm getting is for the 502, so it already has the larger injectors
Old Sep 29, 2004 | 10:37 PM
heavychevy454ss's Avatar
Car: 1990 454SS
Engine: 489
Transmission: TH400
Let us know how it runs.
Old Sep 30, 2004 | 08:00 AM
va454ss's Avatar
Car: 90 454SS
Engine: 454 TBI
Transmission: TH400
Don't worry, I will
db057
Jan 10, 2020 08:55 PM
sailtexas186548
Feb 17, 2017 03:07 PM
Chas91Z28
Oct 22, 2015 10:12 AM
86CamaroDan
Sep 29, 2015 10:08 PM
