Update on My 90rs
Old Oct 3, 2004 | 10:13 AM
Ivon1877's Avatar
Car: 1990 Camaro RS with T-Tops
Engine: 312 TBI(305) 0.040 over
Transmission: out of a v-6 s-10 blazer!
Update on My 90rs
Well got the motor and trans in and took it for a couple test drives! Cant drive it to much because it is not registrered or insured. I was amazed. I actually got a project back on the road!
Anyway I have some issues with the fan! At first it would not come on at all. i replaced the fan relay and it comes on when you turn the ac on! So i thought it was the switch in the head, replaced it and still no automatic fan? Could it be the switch in the manifold? THEN i found out the heater core leaks put a big ol puddle in the passenger floor board S**T! What fun that is going to be! I am gonna try to register it in MS when i go home in a couple of days!
Thanks guys!
Old Oct 3, 2004 | 01:35 PM
KCobain147's Avatar
Car: 91 Camaro RS
Engine: 305 TBI LO3
what size motor are you using?..on my TBI 305, the fan switch was located in the passenger side of the block...down underneath the manifold..so check that one too..when u pull it out coolant should flow all over the place, so be sure that your motor is cool, otherwise you'll end up getting burned.
Old Oct 3, 2004 | 01:55 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
It could be a break in the wiring. With the key to the on position, ground the single wire hooked up to the fanswitch and see if the fan comes on.
Old Oct 3, 2004 | 04:30 PM
Ivon1877's Avatar
thanks guys i did replace the one in the head on the passenger side!
i found out that when the guy helping me might have gotten the wires for the knock sensor and the fan switch mixed up and we swapped them but still nothing. i am gonna try to ground the wire later on!
thanks
ivon
Elephantismo
Feb 13, 2019 12:51 AM
FormulaEngland
European Region
38
Jul 17, 2016 07:33 AM
2012sergen11
Oct 13, 2015 07:38 PM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
aharvel50
Sep 21, 2015 07:31 PM
