350 swapped to a 305
Old Oct 7, 2004 | 04:39 PM
87olds442's Avatar
Car: 87 Oldsmobile 442
Engine: 307 HO
Transmission: 200 4r
I got a camero that had a 350 TBI I got the car with the motor removed. I installed a 305 that I had laying around. My question is what will I have to change to make this run right with my 305. I stil have all the 350 TBI parts. The injector plugs are orange.
Old Oct 7, 2004 | 06:13 PM
Cadillac's Avatar
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
All I am guessing is that you will need a 305 Knock Sensor.
then again, I don't know squat.
Old Oct 7, 2004 | 07:12 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Re: 350 swapped to a 305
Pet peeve #1: It's Camaro
Why would you backslide and lose displacement? Thats silly. What's wrong with the 350 you have now?
Old Oct 7, 2004 | 07:36 PM
87olds442's Avatar
Engine: 307 HO
I bought the car with no motor in it. I have a 305 laying around. I Will be putting a 350 in it later. Its not hard to change motors IMO. BUt I dont want the 305 running rich cause the computer thinks its a 350. I did a little research and found that all aftermarket Fuel injectors are the same. Sooo I think I will be able to use those no problems. I do think I will have to get a 305 computer. I think ?
Old Oct 7, 2004 | 08:41 PM
Benm109's Avatar
Car: 1991 Chevy Camaro
Engine: 305 TBI
You will need a 305 knock sensor, 305 PROM/chip, 305 injectors, and 305 ESC module.
Old Oct 7, 2004 | 09:11 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Correct.
Jake_92RS
Jan 28, 2020 10:37 PM
bellez77
Sep 5, 2015 08:39 PM
st.evel07
Aug 13, 2015 06:15 PM
armybyrd
Aug 10, 2015 09:23 PM
gwade12
Aug 8, 2015 08:17 AM
