manifold advise weiand xceller?
Old Oct 12, 2004 | 05:01 PM
Ronny's Avatar
my xram crossfire replacement manifold is coming off as we speak. i need some advice. do i keep the weiand xcellerator 7547(up to 6500 rpm) i have on now or consider an alternative single plane(torker 2) or run the edelbrock TBI manifold bored to allow my 454 TB to fit? my weiand has about 3/8 inch shaved off the top of it to allow max hood clearance when used with the xram. does that affect its potential? i think i am picking up a full inch more of clearanceto hood. i could possibly have enough room to add a taller intake as the torker 2 or even GM performance parts intake which has raised runners when compared to weiand. think the edelbrock (truck?) can flow enough to support my new cam in sig(5800 rpms)? dont wanna drop in performance! is doing away with the adapter plate and the linkage issues and the gringing away the lip at top of intake(454 TB) worth it to run the Edelbrock TBI but possibly not flow as well as weiand single plane?
Old Oct 13, 2004 | 03:50 PM
va454ss's Avatar
Car: 90 454SS
Engine: 454 TBI
Transmission: TH400
Single plane.
Old Oct 14, 2004 | 10:35 AM
Ronny's Avatar
any others? Holley has EGR which i cannot use. i assume it cam be plugged. any suggestion as to how to plug?
Old Oct 14, 2004 | 12:10 PM
va454ss's Avatar
Car: 90 454SS
Engine: 454 TBI
Transmission: TH400
Originally posted by Ronny
any others? Holley has EGR which i cannot use. i assume it can be plugged. any suggestion as to how to plug?
I have mine blocked with a block off plate. I believe it even has a Holley part no.
Old Oct 14, 2004 | 12:13 PM
Ronny's Avatar
perfect. thanks.
sailtexas186548
Feb 17, 2017 03:07 PM
JSDaddy189
Sep 26, 2015 03:50 PM
TexasMaro
Sep 15, 2015 06:50 PM
R3500
Sep 8, 2015 10:12 PM
