what cam for hydrallic 350?
Old Oct 19, 2004 | 09:49 PM
vic_V8's Avatar
Car: RS
Transmission: 4L60
this is for an lo5....kinda, i have l98 heads for it, looking for torque
Old Oct 19, 2004 | 10:55 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Are the heads modified for lift? If no, then the Xe262 is about all I would attempt to put under them. If they are, then other things come into play. Stall, compression, gears, just to name a few.
Old Oct 20, 2004 | 01:45 AM
vic_V8's Avatar
Car: RS
Transmission: 4L60
well, this is for my truck, didn't want to say it for lock threat, even if it is a TBI motor
Compression is stock......probably 9:1, 5-speed, 3.73 posi
specs (both done, and not done yet)
electric fan swap, 180 stat, Open element, stock L98 heads, long tube headers, 3 inch exhaust, ultimate TBI mods, TBI spacer, timing at 4 advance, custom chip, 3 inch body lift, bar cranks, 35 inch tires
Old Oct 20, 2004 | 01:57 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Look into the 4x4 cams, XE version.
You can hit me up on a messenger service if you have one, contact info in my sig.
I'll be glad to talk to you on there, if you want to avoid the lock.
Old Oct 20, 2004 | 02:31 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
So long as its tbi related you can talk all you want
Old Oct 20, 2004 | 09:58 AM
vic_V8's Avatar
Car: RS
Transmission: 4L60
thanks, its cause I'm a "old timer here" right?
March 2001 baby!
Old Oct 20, 2004 | 01:14 PM
Car: 88 Camaro SC
Engine: SFI'd 350
We decided to bend the rules a tad and so long as a post/thread is tbi related it can be discussed on the boards, regardless of the vehicle.
Old Oct 20, 2004 | 01:19 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
In additon, we do this on the basis that anyone with an LO5 in their f-bod can use the same build information that you recieve.
Old Oct 20, 2004 | 02:49 PM
Gunny Highway's Avatar
Car: 91 RS
Engine: 350 TBI
LO5 is good.
I would look into the Crane selection of cams, specifically their cams for "computer controlled" vehicles. Mine makes great torque (2030) with it's 204/214 duration. Keep your duration low, like below 220 and you should be in the area where you want to make power.
Jake_92RS
Jan 28, 2020 10:37 PM
camaro71633
Sep 1, 2015 10:24 AM
michealleger
Aug 26, 2015 03:29 PM
Eric-86sc
Aug 24, 2015 09:01 PM
theshackle
Aug 22, 2015 06:52 PM
