how much Hp could a TBI system handle?
Old Nov 19, 2004 | 12:46 PM
Borsty's Avatar
Car: 89 Trans am
Engine: TBI 350 HO Vortec heads
just the system itself not the engines that came with it
anyone?
Old Nov 19, 2004 | 01:33 PM
Ronny's Avatar
holley 900 TBI 500 HP?
gm 454 TB limited by injectors? http://www.users.bigpond.net.au/ben_...ctorsizing.xls
check this and assume 90 lbs at 20 lbs and what do you get?
i will have mine on dyno this spring.
Old Nov 19, 2004 | 01:48 PM
Borsty's Avatar
Car: 89 Trans am
i meant like a stock system with a holley 670 TB
sorry i wasnt specific.
Old Nov 19, 2004 | 08:09 PM
va454ss's Avatar
Car: 90 454SS
Engine: 454 TBI
Transmission: TH400
This is a great link and should be made a stickie
BTW, why stop at 20
Old Nov 20, 2004 | 07:08 AM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
That is a pretty cool calculator. It uses the generally accepted formla's, but I have a bad feeling that the generally accepted formula's are wrong. I'm not really sure if it's the DC these injectors can handle at high FP or if it's something else. I plan on doing a little testing with my WB next week.
To answer your question. 300-325 with 90 lb injectors isn't that hard to do. Much past that and your treading the edge. My personal opinion is 400 hp is pretty much it depending on what rpm you make that at.
Old Nov 22, 2004 | 01:08 PM
Ronny's Avatar
why stop at 20 lbs FP?. dont know. what i do know is that i had my vafpr installed a couple years ago and i blew the diaphragm on first crank. i did not have a FPG installed. so i will guess the pre shimmed spring was 12 and after shimming (1/8 in.) was 16 and vac boosted was 26? i assumed the first failure was an old (20 years) dia. i replaced with a new and same result blew right away. so dropped back to 12-13 base FP (i measured the preload/caliper) and it did not fail. now in looking at the vafpr it comes with a "heavy spring" that i did not use so my dia failures may be another issue. call it gun shy. dont know why i had failures.
Old Nov 22, 2004 | 02:11 PM
ben73's Avatar
Yeah, it is a cool calculator. I made it
I also believe that the HP results these "generally accepted formla's" produce is underestimated.
Old Nov 22, 2004 | 05:55 PM
va454ss's Avatar
Car: 90 454SS
Engine: 454 TBI
Transmission: TH400
Well now that you have the Aeromotive reg, raising pressure shouldn't be an issue
Old Nov 22, 2004 | 08:35 PM
BMmonteSS's Avatar
Car: 84' Monte
Thats funny that you were blowing diaphrams at higher pressure, the the diaphram is on the return side of things, so there is no pressure on it, only on the metal piece in the middle. I would be worried about the gasketed surface that holds the injector pod together.
Old Nov 22, 2004 | 08:38 PM
va454ss's Avatar
Car: 90 454SS
Engine: 454 TBI
Transmission: TH400
Never thought of that, really, but............
When I started to jack up the fuel pressure, I trued all the gasket surfaces of the injector pod with a flat file.
Old Nov 23, 2004 | 09:17 AM
BMmonteSS's Avatar
Car: 84' Monte
Good idea, I might try to get my injector pod on the mill at school before I graduate, I'm sure it'll nice and flat then.
Old Nov 23, 2004 | 09:18 AM
Ronny's Avatar
think maybe the preload on the spring being to high caused the failure? i used very thin washers. this was 2 years ago. i measured the stock distance on the threads from stock unit. seeing the vafpr was not adjustable(without taking a torch to it) so i added about 1/8 inch preload. without FPG i had no idea what i was at. this was a feeble attempt in getting car to run better with 65 lb injectos and stock (unhacked) puter. when set at prior preload it did not blow. i still to this day cannot fiqure out how i could blow a brand new gasket. had a tear right next to the plug(?) about 3/16 inch in both cases(old/new).
Old Nov 23, 2004 | 09:32 AM
va454ss's Avatar
Car: 90 454SS
Engine: 454 TBI
Transmission: TH400
I would use caution doing this. You may remove too much material and decrease the size of the return passage on top of the pod.
Old Nov 23, 2004 | 09:36 AM
91RedFirebird's Avatar
Car: 91 firebird
Transmission: t-56
A friend of mine just blew his, he was running a 190 60psi pump but running 13 psi. This is what I think, the return hole is pretty small and is building up alot of psi in the regulator.
Old Nov 23, 2004 | 09:40 AM
Borsty's Avatar
Car: 89 Trans am
i cant use that calculator i need excel.
Old Nov 23, 2004 | 11:23 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
The stock TBI daphram, well, at least the one I had, was subject to full pressure. Its the pressure that pushes teh diaphram and spring back and allows the fuel to return.
Old Nov 23, 2004 | 01:20 PM
BMmonteSS's Avatar
Car: 84' Monte
I need to get some pics of what I'm talking about. The rubber part of the diaphram isn't actually getting pushed by the fuel. It's the metal valve in the middle of the diaphram that actually has the force of the fuel pusing against it. Once the fuel is past that metal tab, it is under no pressure because it is free to leave the TB through the return line.
The theory of the return passage being too small could be true, but I would think you would see problems with the FP refusing to go any lower.
I think alot of people get pressure confused with flow. Your stock TBI pump will make 90 psi of fuel pressure. Just pinch off the return line and it will pump up. Even though it now has 90 psi of pressure it doesn't have any more flow capacity now than it did at 13 psi, actually it has less because the pump is less efficient at higher pressure. So the added pressure isn't going to make the restrictive return port any more of a problem than with the lower pressure.
I think there is a problem with high spring pressure on the diaphram causing it to kink or flop over in the housing putting a tearing force on the rubber part of the diaphram. Rbob posted a datalog wher his regulator was draging the pintle on the seat cause eratic pressure when he would blip the throttle, I think we may have the same problem at higher spring pressures, it could even be so bad that it tears diaphrams.
Old Nov 23, 2004 | 02:43 PM
Car: 91 firebird
Transmission: t-56
I could see that, this is what I'm talking about there retrun passage in the regulator this one is less than 3/16
Old Nov 23, 2004 | 02:51 PM
BMmonteSS's Avatar
Car: 84' Monte
I guess my arguement is that the return passage is fine unless you run into an issue that you can't turn the fuel pressure down far enough. This would be most likely at idle since most of the fuel is bypassed at idle. Some guys have ran into this problem with the 255 lph walbro pump on fairly mild combo's. I ported mine out a bit just for good measure.
Old Nov 23, 2004 | 03:12 PM
Car: 91 firebird
Transmission: t-56
write some thing up, How not to burn your TBI F-body down to the ground By BMmonteSS
Old Nov 23, 2004 | 04:44 PM
va454ss's Avatar
Car: 90 454SS
Engine: 454 TBI
Transmission: TH400
What did you use?
Hmmm. Extrudehone comes to mind
Old Nov 23, 2004 | 04:59 PM
Car: 91 firebird
Transmission: t-56
Just drilling the hold deeper will open it up alot same for the inlet side.
92projectcamaro
Jan 18, 2016 08:00 AM
fasteddi
Sep 10, 2015 09:32 AM
Slush92RS
Sep 2, 2015 08:56 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
