valve covers
Car: 89 iroc
Engine: 355 TPI FINALLY
Transmission: 700r4/ SHIFT KIT
valve covers
would it work to turn the right valve cover so the breather is at the front? instead of the back of the engine
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
Re: valve covers
the valve covers are "tilted" inside... the rockers might rub if you flip it...
if they do rub or not depends on your valve lift and type of rockers you have.
Car: 2002 Z28
the covers can only be put on one way, if you try to flip them then the centerbolt holes in the heads will not align with the bolt holes in the valve covers
Car: 1991 Trans AM GTA
Engine: 5.7L TPI
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
