How much PSI
Old Nov 22, 2004 | 07:01 PM
91RedFirebird's Avatar
Car: 91 firebird
Transmission: t-56
How much PSI
How much psi can i run before injector seal failure or driver failure. Looking at other post I think some one said they where tested to 70 psi, but for how long? How well will my 15 year old drivers hold up to that kinda abuse?
Old Nov 22, 2004 | 08:00 PM
JPrevost's Avatar
Car: 91 Red Sled
You could run a bunch of pressure without fear of harming the ecm drivers. I'd guess pressure up to 30psi would be fine.
Old Nov 22, 2004 | 08:35 PM
va454ss's Avatar
Car: 90 454SS
Engine: 454 TBI
Transmission: TH400
From an email message from Walt Sherwin dated 8/25/03:
"17084304 is the stock (1990 - 1993 454) SS injector. The service part number is 17112560. It is rated at 75 lbs/hr of spec fuel, at 10.5 psig differential pressure. There was once a larger flowing injector manufactured and used in the early 80's, and in fact I have one that I've tested on the bench. The engraved number on top is RPD 17111784. It flowed around 80 lbs/hr, versus the 17084304, under the same conditions. However, you want to stay as far away as possible from those as the electromagnetics were terrible, they were quite sluggish, and beyond about 18psig they don't flow properly. There were larger alcohol injectors made for the Brazil market, but the last time I checked they were no longer available. Bottom line, stay with the 17084304 and crank the pressure until you get the delivery you need. I've run those puppies at 70+ psig fuel pressure !!!"
Old Nov 23, 2004 | 09:31 AM
va454ss's Avatar
Car: 90 454SS
Engine: 454 TBI
Transmission: TH400
FWIW, at this time, I run 33 idle, 42 WOT
Old Nov 23, 2004 | 03:07 PM
Car: 91 firebird
Transmission: t-56
Thanks for the info!
Old Nov 23, 2004 | 10:38 PM
Low C1500's Avatar
Car: 89 Shortbox
Engine: 350 Vortec
16 year old injectors, at 30psi. No problems.
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
dusterbd
Sep 29, 2015 08:40 AM
