Another Update... How much more abuse will this 305 take.
Old Oct 25, 2004 | 10:46 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
I'll update with more pics when I get home. This is the only one I had tossed into the /var/www folder. So check the posting again later for more pics.
Old Oct 25, 2004 | 10:52 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I think a few passes with the 100 shot are going to do you in. Oh, well...then you can start on that 327 You can start even faster if you spray with that miss still present
Old Oct 25, 2004 | 11:03 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Miss will be figured out before i spary it.
I have jets for up to 150 plate is good to 250.
I'm hopeing to go 12's with the juice on. I was chasing down a Eclips that ran 14.3, would have beat him, if it wasn't for the miss. So with 125 extra, 12's are very doable, or so I think.
Everyone... Please keep my tranny in your prayers.
Old Oct 25, 2004 | 11:25 AM
91RedFirebird's Avatar
Car: 91 firebird
Transmission: t-56
most stock short blocks IE cast pistons rods bolts will have problems with juice above 400+ hp after a while. Have you up graded the ignition? IF not you might not burn all the mix. I don't think you will be able to go from 14's to 12 with out losing the motor, but it would be fun to try.
Old Oct 25, 2004 | 11:29 AM
Dewey316's Avatar
Car: 1990 Camaro RS
I've got a 327 in the garage, that is going to be my twin turbo project. So if I blow this up, I'll get a cheapo 305 for $100, and then start working hard on the 327
Old Oct 25, 2004 | 11:37 AM
Benm109's Avatar
Car: 1991 Chevy Camaro
Engine: 305 TBI
Dewey316, are you going to stay TBI with the TT 327? I hope you are .
Old Oct 25, 2004 | 11:39 AM
Dewey316's Avatar
Car: 1990 Camaro RS
it will likely be some form of MPFI. It is a long ways off. I have a block and crank, both of which need machine work, thats it, gotta build up EVERYTHING.
Old Oct 25, 2004 | 11:47 AM
flrtin1's Avatar
Car: Z/28..39 Plymouth truck in progress
Engine: S/B
Transmission: Manual
lol, I have 2 small journal 327 cranks and a 69 327 long block sittin in the garage waiting for the 305 to blow up bad enough to be replaced............been 19yrs and it still hasn't happened
Old Oct 25, 2004 | 11:48 AM
Car: 91 firebird
Transmission: t-56
How do you have your system set up? DOes it come on with wot or just on? just on with a switch and a 5-speed would be bad bad bad. a wot switch you could get it moving in gear first and hopefully save the trans and rear from heavy shocks
Old Oct 25, 2004 | 11:52 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Its going to be activated by a microswitch attached to the throttle linkage. So only WOT will activate, when it is armed. Jacobs MM will be on before next race season.
flrtin1-- I wouldn't mind finding a SJ 283 crank. Just to keep my car a 5.0L
Old Oct 25, 2004 | 11:57 AM
Car: 91 firebird
Transmission: t-56
I do belive I have a SJ 283 crank or a few of them laying around. what About fuel pressure on the plate? I would put in a regulator for a carb in the nos system to keep from adding to much fuel.
Old Oct 25, 2004 | 11:58 AM
Dewey316's Avatar
Car: 1990 Camaro RS
I bought the jets for my FP. I spent hours talking to NOS and Holley Techs.
Old Oct 25, 2004 | 12:00 PM
flrtin1's Avatar
Engine: S/B
Ya......... thats sorta what I was thinkin also. The forged pistons that I have in the 305 now were discontinued from TRW a long time ago so next time I need a piston (or worse ) it will be time to decide which way I am going to go.
Old Oct 25, 2004 | 12:06 PM
Dewey316's Avatar
Car: 1990 Camaro RS
I'm sticking the SJ crank since its forged. Billet mains. Eagle ESP SJ Rods, TRW 327 forged blower pisons, and ARP hardware. It should hold some power.
Old Oct 25, 2004 | 12:24 PM
Car: 91 firebird
Transmission: t-56
I can only dream of a tt sb, I would go with a long rod set up and a lighter piston, given any thought to rings and head gaskets?
Old Oct 25, 2004 | 12:25 PM
BronYrAur's Avatar
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
Sounds great Dewey! It's been a while since there has been a new car breaking into some really fast times, I think that's your job now. I can see it definitely making it to the 12's.
I'm prayin for that 5-speed to hold up haha. What are you planning to do transmission-wise with the 327 setup?
Old Oct 25, 2004 | 12:27 PM
Dewey316's Avatar
Car: 1990 Camaro RS
No, I'm still in the very early planning stages. head gasket ect. will depend on what the deck ends up at, etc. Its all about the quinch area.
Old Oct 25, 2004 | 12:41 PM
Car: 91 firebird
Transmission: t-56
I wish!
Attached Thumbnails Another Update... How much more abuse will this 305 take.-turbo.jpg
Old Oct 25, 2004 | 02:52 PM
flrtin1's Avatar
Engine: S/B
Of course the 305 is still running pretty good Video
Old Oct 25, 2004 | 11:44 PM
25THRSS's Avatar
jacobs mastermind would go nice with that setup.
Old Oct 26, 2004 | 01:04 AM
90RS305's Avatar
Car: 96 Silverado/99 Suburban
Engine: 700 cubic inches of 'Muican Awesome
Transmission: 4L80/4L60
Axle/Gears: Chunky/Clunky
Jeebus, I'm on a 4000kbps connection and it said 16min to d/l!
Old Oct 26, 2004 | 01:30 AM
flrtin1's Avatar
Engine: S/B
Heh, sorry for some reason when I copied that file to that folder it almost doubled in size try it now its still sorta big 5+meg.
Old Oct 26, 2004 | 01:40 AM
90RS305's Avatar
Ehh, still perdy big, ohh well, I believe you
Old Oct 26, 2004 | 01:04 PM
flrtin1's Avatar
Engine: S/B
ok, ok here is the sound clip Sound even though the vid is "cooler" lol
Old Oct 27, 2004 | 10:51 PM
irocbirdbuilder's Avatar
Car: 91 Camaro RS
Engine: TBI
damn flirtin, i'll have to watch it entirely at work on high speed cause at home it would only play about 6 sceonds and tehn buffer and so on looks and sounds bitchin though:hail:
Old Oct 28, 2004 | 12:01 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Ok... here are a few more pics...
Had to go to studs on the intake, with the nitrous plate + adaptor, it was just too thick.
This is a good shot of how the spray bar sits.
Got Plenum?
Old Oct 28, 2004 | 01:19 AM
BronYrAur's Avatar
Engine: 305 TBI
Nice! That looks really good Dewey, I like how that all went together.
Old Oct 28, 2004 | 08:24 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Lookin' good man. Hope to see some track times soon.
Old Oct 28, 2004 | 08:35 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Best I will be able to do for times, is G-tech and Dyno. This weekend is the last weekend of racing here in Portland, and 2 fittings are back-ordered from summit. So she sits until Dyno runs in January.
Old Oct 29, 2004 | 07:07 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Here are some more pics.
Bottle mounted.
And an interesting shot of me testing the FP with a hacked up stock fuel line. Since I still don't have all the fittings for the braided lines, in which I put an integrated FP port.
Old Oct 29, 2004 | 06:08 PM
25THRSS's Avatar
Very sweet setup if I do say so myself. Keep us updated.
Old Oct 29, 2004 | 08:22 PM
JPrevost's Avatar
Car: 91 Red Sled
Dewey, you and I think alike... why bother with a TBI nitrous plate if you're using a carb intake....
And the way you did your fuel pressure gauge mounting, just like me .
Good luck hitting that 305 with nitrous. Camaroracer1992 (Joe) was running 125 shot from the green light! So if you're only having it come on with WOT, hopefully your engine will have some oil pressure... if not, 305 will develop rod knock. Good luck with it though and a 327, yup, that's also my favorite GM motor .
Old Oct 29, 2004 | 09:11 PM
redlightrunner's Avatar
sick *** dude
Old Oct 29, 2004 | 09:19 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Jon,
I've never had a oil pressure issue. holds 40psi at idle. Hopefully it will hold. Truth be told, I hadn't put much thought into blowing the motor, I've also figured the T5 will die first. And especialy with the availability of used carb nitrous kits, I picked mine up for $100, then just bought some extra peices, I am still money ahead, after buying TONS of braided lines and fittings, along with a brand new plate and jets.
As soon as summit ships the last of the -AN fittings out, I'll get the feed side of the lines finished up, on the new feed line, there is a 1/8 NPT port that is now located near the firewall, so fuel pressure tests will be much easier to perform.
Old Oct 29, 2004 | 11:30 PM
BadBlue91RS's Avatar
Car: 1991 Camaro RS
Engine: Briggs & Straton
Transmission: Centrifical Clutch
JEEBUS flrtin1!!! Whats that thing run?!?!
Old Oct 30, 2004 | 12:10 AM
90RS305's Avatar
My words exactly. Sick work with the chrome reflection too! Yeah, we need some specks on that beast...
Old Oct 31, 2004 | 01:56 PM
flrtin1's Avatar
Engine: S/B
I ordered it in late 84 got it in mid 85 put a blower on it in 86 so most of these parts have been long since discontinued lol
305 w/TRW 7.5:1 forged (true dish) pistons
2.02/1.60 ported/pinned heads (76cc)
B&M cam and lifters (lost the cam card so I don't know the exact specs but it was the cam for over 7lbs boost)
1.5 rollers
Pete Jackson gear drive
Black Jack ak5000 headers (2" true dual exhaust)
Custom Carter Competition Series 500 CFM carburetors
B&M 420 cubic inch Megacharger (9lbs. boost)
(had a B&M 144 on it from 86 to 90 15lbs boost)
Mallory Unilite distributor / MSD 6AL ignition box
MSD Adjustable Spark Timing Control
MSD Soft Touch rev limiter / MSD SS coil
car has 66k+ miles on it 55k+ have been supercharged
I get over 22mpg highway in town it varies with how I am driving
As far as times the last time I had it to the track was in 88 and that was with a different blower/heads/ignition system.
I do have a good idea what it runs, but don't have the numbers to back it up so I wont post anything, lets just say it does alright
More videos
Old Nov 6, 2004 | 03:25 AM
RSFreak's Avatar
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
Hey John, how many miles do you have on that engine? I am toying with the idea of spraying my L69, but at 170000+ miles I don't think shes gonna hold up.
Old Nov 6, 2004 | 10:38 AM
Dewey316's Avatar
Car: 1990 Camaro RS
174k
I might very well blow it up very quickly. I think the poor T5 will die first though.
Old Nov 6, 2004 | 05:27 PM
RSFreak's Avatar
My 700R4 was rebuilt recently, so I'm more concerned with the engine. That is still a ways down the road though. For now you can be CC's fastest 305!
Old Nov 11, 2004 | 06:53 PM
miacamaro305's Avatar
Car: 89 Camaro RS
Engine: 5.0 tbi
Transmission: street-strip 700R4
Hey dewey, i have looked at this thread for about 1 week straight to try to see if i could ever get to look at your picsoff your set up. Has anyone told you about it? I am baddly wanting to see you set up. Have you gotten that nitrous running yet?
If you can can you send me some of those pics threw my pm.-Eric
Old Nov 11, 2004 | 06:55 PM
  #42
90tbi305's Avatar
Car: 1990 350 tbi l98,
Engine: 5.7 tbi
Transmission: t5
my bad wrote with my buddys screen name. Eric this time.
Old Nov 11, 2004 | 07:31 PM
  #43
Dewey316's Avatar
Car: 1990 Camaro RS
I'll get them back up for you.
Old Nov 11, 2004 | 11:02 PM
  #44
90tbi305's Avatar
Engine: 5.7 tbi
Transmission: t5
You are the man. What adapter are you using for the carb>tbi?
Have you shot nitrous yet? If so how does it feel?
Old Nov 11, 2004 | 11:39 PM
  #45
Dewey316's Avatar
Car: 1990 Camaro RS
Its a super-powershot plate, with the holley adaptor. I had to remove the spacer ring, and trim the air-cleaner stud to get it to fit under the hood.
Car wouldn't start last week when i tried to fire it up, so i need to chase that down first (I think the fuel pump may have died....again.)
I'm also still waiting for 1 fitting to ship from summit, so I can finish converting the fuel lines to braided.
Old Nov 22, 2004 | 09:58 PM
  #46
Car: 89 Camaro RS
Engine: 5.0 tbi
hey dewey what jets are you using?
Old Nov 22, 2004 | 10:00 PM
  #47
90tbi305's Avatar
Engine: 5.7 tbi
Transmission: t5
This is the second time i do it. -Eric
Old Nov 23, 2004 | 12:27 AM
  #48
Dewey316's Avatar
Car: 1990 Camaro RS
I put 100 in this weekend, it took it like a champ. I'm going to be upping it to 150.
If you wanna see what 100 is like....
CLICK HERE
(yes, my tach is very broken, there is an aftermarket on the left side of the steering wheel
LINK FIXED
Old Nov 23, 2004 | 12:30 AM
  #49
flrtin1's Avatar
Engine: S/B
link not working
Old Nov 23, 2004 | 12:40 AM
  #50
flrtin1's Avatar
Engine: S/B
Nice run sounds great
