Question about air intake
Old Nov 23, 2004 | 08:36 AM
Jerriko 3.4's Avatar
Car: 1987 Firebird Formula
Engine: 3.4L 207 V6
Transmission: T5 W/C
There is a tube that connects from the driver side exhaust manifold to the bottom of the air horn. Does anyone know what it is and what it is for? The tube on the car I am parting is rotted away and I would like to know it this hurts anything.
Thanks,
Jim
Old Nov 23, 2004 | 08:41 AM
305q_ta86's Avatar
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
Sounds like the THERMAC. What happens is, when the incoming air is really cold - too cold, there is a little sensor inside the air cleaner that will supply vacuum to a solenoid that will open a little door right above where that tube connects. Then hot air from around the exhaust manifold will rise up through the tube and help to heat the engine up faster. This is a good thing. If you live somewhere where it gets faily cold, I strongly reccomend you keep that piece. I have removed it on my car before, and the result has been apparent in a few things. For instance, the engine will sometimes 'diesel', or continue to run, after I turn the key off. Again, bad. But that only happened when I had my cold air intake installed, and then what I think happened was that it got too much cold air, and the THERMAC couldnt compensate properly. Then again, it was like ten below at the time.
Hope that helps.
Old Nov 23, 2004 | 08:43 AM
Engine: 3.4L 207 V6
Yeah, thanks for the answer. Seems easy enough.
1992 Trans Am
May 10, 2023 07:19 PM
PestilenceIV
Aug 20, 2015 02:33 AM
kyle5647
Aug 15, 2015 11:56 PM
Jake_92RS
Aug 11, 2015 10:39 AM
