305 0r 350 tbi
Old Dec 5, 2004 | 05:52 AM
tonys91rs's Avatar
Car: 91 Camaro RS
Engine: 305 TPI conversion.
305 0r 350 tbi
i picked up a tbi which i was told it came from a 350. im wanting to do the ultimate tbi mods and also obtained a spacer and pod spacer. my question is are the 305 and 350 tbi the same? can i switch the pods from my 305 onto the 350 base after i modify it and clean it up?
Old Dec 5, 2004 | 12:44 PM
Benm109's Avatar
Car: 1991 Chevy Camaro
Engine: 305 TBI
From what I understand, the 305 and 350 TBI units are exactly the same, except for that the 350 TBI units came with bigger injectors (not proportionally bigger, just better flowing). So, yes, you can swap most of the parts between the 2 with no problems.
The only problem I can think of is that some of the 350 TBI trucks had two studs for the stock air cleaner assembly. I'm not sure if you can remove or modify them or not, but I bet you can.
Hopefully someone more knowledgeable than me while confirm this.
Falcon50
Aug 22, 2020 03:26 PM
FormulaEngland
European Region
38
Jul 17, 2016 07:33 AM
92projectcamaro
Sep 29, 2015 07:07 PM
Gordonr1973
Sep 29, 2015 11:59 AM
Bigold4x4
Sep 28, 2015 05:21 PM
