lt1 or ls1 head fit?
Old Dec 10, 2004 | 08:46 AM
frogmanjohn's Avatar
Car: 89 RS
Engine: 305 TBI 215,000+
will lt1 or ls1 heads fit on my 305 tbi? never looked closely.
john
Old Dec 10, 2004 | 10:08 AM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
I saw some where on TGO where LT1 heads would fit gen one block with extensive modification and then use of lt1 would be preferred and practical. But anything close to direct, NO, not at all.
Old Dec 10, 2004 | 10:33 AM
BronYrAur's Avatar
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
LT1's have reverse flow cooling. They won't match up to your block right and aren't worth any modification to fit. LS1 heads are completely different.
Old Dec 10, 2004 | 11:15 AM
Car: 89 RS
that's what i needed, thank you.
john
Old Feb 7, 2005 | 08:22 PM
dusty89camaro's Avatar
Car: 91 Camaro RS
Now I'm confused. Are you sayin that the LS1s are different than the LT1s or are they different from the stock heads?
Do you think LS1 heads would fit on my 89 350 (carb)?
-dusty89camaro
Old Feb 7, 2005 | 08:30 PM
Car: 91 Camaro RS
Alright Lt1 heads and Ls1 heads are not the same. LS1 heads have never been put on a gen 1 block. With a bunch of work Lt1 heads have been put on a gen 1 block. Stock heads are gen 1. Vortec heads are gen 2, however will bolt-on relatively easy except you have to use vortec style intake. A lot of Gen 1 block and Gen 2 block are the same except when it comes to reverse cooling.
Old Feb 7, 2005 | 09:10 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
LS1 heads are a whole other animal and will not work at all.
LT1 heads can be made to work with extensive work to them but it is not worth it on a 305 TBI.
416, 081 or vortecs are your best bet.
Frozer!!!
Jan 19, 2024 04:55 PM
midge54
Dec 27, 2019 04:14 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
sreZ28
Aug 14, 2015 07:48 PM
