help with scanning
Old Dec 23, 2004 | 09:03 AM
joes350tbi's Avatar
help with scanning
i have a 94 truck 350, i need directions on how to scan this thing.. is it 160 baud, 8192 baud, need to know what program to scan with, and what cable needs to be used? ive tried several ways, so im just going to start fresh. ive got win aldl, datamaster, i bought a cable?? nothing works for me....maybe im just not hooking the cable up right...i dont know.
so if anyone has a truck running $od, help me out please.
Old Dec 23, 2004 | 11:14 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Thats the later model PCM rather tehn one of the earlier ECMs. You should be able to scan it with the 8192 baud software (winaldl wont work at the higher baud rate). Itll also need a different cable then the standard single transister one, if thats what you have, as its a two way connection.
Old Dec 23, 2004 | 01:26 PM
joes350tbi's Avatar
anybody know of a specific cable i can buy, with good instructions on how to hook it up?
my biggest problem is figuring out where to put which wire on my plug, b/c where it says im supposed to plug in, there isnt a terminal to plug into.
Old Dec 23, 2004 | 06:24 PM
Cadillac's Avatar
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
I have no doubt the gang on the DIY PROM board will be expert on this. I WISH I knew what they knew.
Look for posts by Grumpy.
Old Dec 24, 2004 | 01:41 AM
ben73's Avatar
I have a very similar TBI PCM ($e6).
I use datamaster with a cable from www.mastach.com (9pin serial), and it also works well with my moates USB cable.
1992Z28!
Nov 19, 2015 07:33 AM
RGB2015
Sep 20, 2015 09:26 PM
NufNuffZ28
Aug 14, 2015 09:12 AM
Corry
May 31, 2001 08:52 PM
Mark305TBI
Jan 28, 2001 11:20 PM
