Should i buy heads or cam?
Old Dec 27, 2004 | 09:50 AM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
I have some christmas money left over and i found an LT1 cam and a set of L98 heads that i can get for the same price, But i can only get one of them. Which one should i buy?
Old Dec 27, 2004 | 10:19 AM
Benm109's Avatar
Car: 1991 Chevy Camaro
Engine: 305 TBI
I'd say LT1 cam, but, how old are your valve springs on your heads? I know you did a rebuild recently, did you replace them then? I've heard that if the valve springs are too old then the LT1 cam will be too much for them.
Can you burn your own PROMs, or is someone else doing that for you?
Old Dec 27, 2004 | 10:45 AM
bbtaz97's Avatar
Car: 91 RS
Engine: 350tpi comming soon!
Transmission: fixed the 700r4 again!
definily the cam first .. then the heads.. besides l98 heads with 64 cc's with drop your compression unless you ahve then milled and thats mroe money...
also you will definitly need PROM tunning form someone who know swhat they are doing and not a guess or it wont run right. Trust me i know. I finally jsut bought the PRom stuff myself
Old Dec 27, 2004 | 04:05 PM
vic_V8's Avatar
Car: RS
Transmission: 4L60
if those were 58 cc heads, I'd say the heads, but since they aren't cam.
Old Dec 27, 2004 | 05:19 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Pass on the 083 heads for now. Even with the drop in compression they are better than the stockers. However, you can do better since there are millions of cheap 305 heads out there that will work better. So for now ****** up the cam. Just look how much fun Dewey is having on the stock heads
Old Dec 27, 2004 | 05:37 PM
azvolfan's Avatar
Car: currently thirdgenless!!!
If you can't do both, go for the cam. TonyC out here in PHX is running 15.1's with stock heads and an LT1 cam. With headers and a small amount of chip tuning. He's got me by almost .5 seconds, FOR NOW!!!!!
Old Dec 27, 2004 | 08:37 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
Well I actually just figured out that i can probably get both.
So i will see better results with 305 Heads?
Old Dec 27, 2004 | 08:50 PM
BronYrAur's Avatar
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
Yes. Get some 305 TPI heads 081's. They have the same flow characteristics as L98 heads but have smaller chambers (58cc) to keep your compression where it is.
Old Dec 27, 2004 | 08:54 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Correctomundo. They are also more plentiful than L98 heads and should be easier to find.
Old Dec 27, 2004 | 10:35 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
Awesome! Well i figure with the heads and cam,and maybe intake, hopefully ill be able to turn some pretty good times.
84z96L31vortec
Aug 20, 2017 12:16 AM
Mickeyruder
Sep 2, 2015 02:45 PM
theurge
Aug 21, 2015 12:46 PM
86White_T/A305
Aug 17, 2015 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
