O2 WinALDL Reading
Old Dec 29, 2004 | 04:03 PM
squirrel's Avatar
O2 WinALDL Reading
A non 3 gen TBI question if possible. At an extra long traffic light recording data, before stop, the O2 readings are normal, hitting hghs and lows, if I'm correct. newbee I am. It goes down to readings of .075 - .195ish for 7-8 data points, IAC reading is 17 through these points. This is at idle. At normal drving it hits the high and lows. At an idle, out of gear, I have an intermitent miss maybe abt ever 30-40 sec, or so. Is it normal for the readings to be like this? Just starting out and have not seen this before on any recordings. Trying to adjust a rich idle. Thanks
Old Dec 30, 2004 | 09:49 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Have you done any mods? Sounds like its going into open loop when idling and running a tad lean.
Old Dec 30, 2004 | 09:23 PM
squirrel's Avatar
Thanks Dimented, no mods, stock L05 truck motor. As stated, new at this, in WinALDL, how do I tell when its in open loop. It idles abt. 675, with the IAC readings, 17 and below. How do I get out of open loop or is that where I need to be at idle. The BLM's, I have gotten down to 126, INT's right at 128. Thats a good reading, yes. Mercie, this is addictive, now, open loop? Thanks my friend
Bubbajones_ya
Jul 6, 2024 08:32 PM
sahlomonic
Sep 20, 2015 07:15 PM
eustodp
Sep 20, 2015 05:09 PM
Rally Smith
Sep 14, 2015 06:59 PM
sandman92084
Sep 12, 2015 10:27 PM
