injectors quit intermit.. fuel pump maybe?
Car: 89 RS
Engine: 6.3L Megasquirted HSR
Axle/Gears: 3.70 Posi 9 bolt
This just started today. I cranked up the 'maro cuz it hasnt been drivin around in a while. I was sittin in the car when I noticed the motor kinda stalling, no backfiring or nething like that. I hit the gas, and it was alright. then back to the same thing. I popped the hood and cranked the motor. I figured since it wasnt backfiring, it wasnt getting enough fuel. sure enough, both injectors just seem to shut off at times. not one, then the other, but both at the same time. Could this possibly be a bad fuel pump, or cud a clogged fuel filter do this? I dont know if its throwing any codes, cuz I got the gauges out right now. any ideas?
It problably is your fuel pump.Just got mine replaced yesterday.It was doing the same thing.But you need to check your fuel pressure first or you can spend a lot of money like I did before I figured that out.
92camaroJoe
Aug 13, 2015 06:07 AM
