nitrous into a tbi motor question...
Old Jan 18, 2005 | 10:17 PM
white91formula's Avatar
Car: 91 formula
Transmission: t5
ok i have a nx wet kit here with the shark nozzle... and i was wondering, instead of buying the plate that goes under the tb, would it be ok to just drill a hoel and tap the nozzle inot hte spacer for the air cleaner that goes around the outside of the injectors ? and would it be a problem spraying it into only one of the 2 sides of the tb ?
Old Jan 18, 2005 | 10:27 PM
nidyanazo's Avatar
Car: Gutted 92' RS TRACK ONLY / '86 Mustang gt 'vert / 1982 Yamiaha xs400 Cafe Racer
Engine: L03; TBI is IT! / 5.0HO (306) SFI / 400cc air cooled twin
Transmission: 700-r4 / WCT5/ 6-speed close ratio
Drill it in the center, not to one side.
Old Jan 18, 2005 | 10:49 PM
Car: 91 formula
Transmission: t5
it wouldnt be spraying it into the bowls then, just into the tb an dnot actually down into it....
Old Jan 18, 2005 | 11:47 PM
BronYrAur's Avatar
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
I would get the plate. Your distribution wont be as good going in outside with the injectors. Plus its a dual plan manifold so if you spray into only one throttle bore you'll only be feeding four cylinders the nitrous. Get the plate, you'll make the best power, be the safest way and get the best distribution.
Old Jan 19, 2005 | 05:17 PM
njspder's Avatar
Car: 1976 Camaro LT
Transmission: TH350
if you feel liek beign a little creative you could make a top mount for it. sort of like the nozzle kits that NOS sells that go above a carb. all you would need to do is make a small angled mount to hold the nozzle up on the frotn side of teh tb.
jsut make sure it is centered and that the bracket is stiff enough to not wave around under acceleration or when shooting.
good luck with it
later
tim
BRoss99
Aug 10, 2025 05:08 PM
MustangBeater20
Oct 29, 2022 09:20 PM
evilstuie
Jan 9, 2020 08:29 PM
Dwayne614
Sep 28, 2015 08:33 AM
happyhapka
Aug 15, 2015 04:42 PM
