Bolt-on Vortec heads in TBI Blocks?
Old Jan 19, 2005 | 08:53 PM
Raul_Chile's Avatar
That is my question, or I need modify something in block(TBI 1990) as holes, bolt, gasket, ..?
Here in CHile is more easy to get Vortec heads that L98, vette, etc.
I did a search but don´t found a good link
Thaks
Old Jan 19, 2005 | 08:56 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
They will bolt right up to your TBI engine. You will need a vortec intake to accomodate for the unique bolt pattern of those heads. GM makes a vortec intake for TBI and many companies make vortec carb intakes that can be used with an adapter plate.
Old Jan 20, 2005 | 10:20 PM
Raul_Chile's Avatar
Re: Bolt-on Vortec heads in TBI Blocks?
Thaks
OK, but what happen with large pushrod?. are equals in large pushrod TBI Block and Vortec?
Old Jan 21, 2005 | 11:36 AM
BronYrAur's Avatar
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
You can reuse your stock pushrods on the Vortecs if they're still straight. A TBI block is no different than any other V8 block.
Old Jan 22, 2005 | 11:00 PM
Raul_Chile's Avatar
Re: Re: Bolt-on Vortec heads in TBI Blocks?
Ok, thanks
I will get then a pair of L31
Old Jan 23, 2005 | 07:35 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
You will need another intake. The vortecs have a different bolt pattern and the intake ports are taller (they wouldnt be vortecs if they werent).
Old Jan 23, 2005 | 09:02 PM
Raul_Chile's Avatar
Re: Re: Re: Bolt-on Vortec heads in TBI Blocks?
Ok, thanks
I know that now. I will get a intake from USA via summit catolgue.
Today I and friends probe us a V6 Vortec Engine with custom intake and carburator 2 barrel Holley. Very niceˇ
But we need change or put other pump, in high RPM no working fine. But in general we are happy´s.
The Engine went put in Body Dayhatsu Rocky 4x4.
MustangBeater20
Oct 29, 2022 09:20 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
bamaboy0323
Sep 3, 2015 06:07 AM
L98GTA87
Aug 11, 2015 06:55 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
