oil sender or sensor?
Old Mar 7, 2005 | 11:05 AM
The Shadow's Avatar
Car: 1989 Camaro RS
Engine: 305 V8 TBI
I have an 89 TBI RS. My oil pressure guage does not work. Which sender or sensor controls the guage? There is one just above the oil filter and another just above the starter. Which one does what?
Old Mar 7, 2005 | 11:22 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
In your car, it should be next to the dist. Itll be a metallic canister screwed into a fitting on the china wall.
Old Mar 7, 2005 | 12:02 PM
The Shadow's Avatar
Car: 1989 Camaro RS
Engine: 305 V8 TBI
I will have to go look for that. however, what is that sender with 3 wires just above the oil filter. Somone told me it was a sender/sensor combo.
Old Mar 7, 2005 | 09:34 PM
Car: 88 Camaro SC
Engine: SFI'd 350
Sounds like it could be the combination sendor/switch. In the later years gm phased out the sendor for the oil pressure and combined them into one part.
Old Mar 11, 2005 | 02:49 PM
92blue's Avatar
Former Sponsor
Car: 1992 Camaro RS
Engine: Yet another 350 TPI
Transmission: Borg Warner 6 spd
The one you have with 3 wires right above the oil filter is your oil pressure sending unit. Older models used a different method as dimented24x7 described. The one you are referring to right above the starter is your fan temp switch. It turns on your fan when the coolant reaches a certain temperature.
Old Mar 11, 2005 | 09:07 PM
v8nate92RS's Avatar
Car: 1992 Camaro RS
Engine: 305 L03
Transmission: Borg-Warner WC T-5
My guage just started reading wacky the other day. I guess I'm gonna have to get this freakin thing fixed too.
Old Mar 11, 2005 | 09:47 PM
steve8586iroc's Avatar
I believe the sending unit above the oil filter is for the oil pressure guage and also a fuel pump cut off switch. If your oil pressure guage is going whacky it's probably the sending unit. I've had to replace two.
Steve
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
willyjoejr
Sep 3, 2015 09:26 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
