Mainfold Gasket
Old Mar 23, 2005 | 02:52 PM
Coult_91's Avatar
Car: 91firebird, 2000 camaro
Engine: 305 tbi,K&N, edelbrock intake & 3.8
Mainfold Gasket
do i need to take everything off the mainfold to change it? or can i leave the trottle body on? thanks
Old Mar 23, 2005 | 04:05 PM
Benm109's Avatar
Car: 1991 Chevy Camaro
Engine: 305 TBI
You sure can if you want to. The only things you really have to remove are the distributor, air cleaner, the 3 cables that attach to the TBI unit (TV, gas, and cruise control cables), upper radiator hose, and intake manifold bolts. Although, all the wiring, vacuum lines, etc. will have to be moved out of the way, of course.
But, it will be easier if you remove most of the stuff attached, especially when your reinstalling it. It's not easy or fun to try and position the intake manifold slowly and carefully back on the motor with all the stuff still on. And, if you do it this way, you will have a great opportunity to replace all of the other gaskets that are or will end up needing replacement anyway, like the TB mounting gasket, thermostat housing gasket, etc.
It's all up to you. Good luck.
Old Mar 23, 2005 | 04:43 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
You can leave it on but as Benm saids by the time you unhook everything only 3 bolts will be holding it on. I always just take it off so that I have clear access to the intake bolts.
db057
Jan 10, 2020 08:55 PM
sheachopper
Jul 31, 2019 11:27 AM
TP355Z
Exterior Parts Wanted
Oct 21, 2015 01:05 AM
Jonas Earl
Sep 27, 2015 07:39 AM
hdis2002
Sep 8, 2015 02:52 PM
