Muffler/Cat In/Out sizes
Old Apr 21, 2005 | 07:32 PM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
Transmission: TH-700-R4
I need the inlet and outlet sizes of the stock 305 TBI muffler and cat. Do I order the same size or a little bigger?
Old Apr 21, 2005 | 07:34 PM
RS Chris's Avatar
Car: 1991 RS
Engine: 5.0
Stock is 2.25" I believe. You should consider a full 3" inch system for your car.
Old Apr 21, 2005 | 07:37 PM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
Only purchasing muffler and high flow cat.
Both are 2.25 inch in and out?
Old Apr 21, 2005 | 09:40 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
The entire TBI exhaust is 2.25". I would hate to see you spend money on the same size. You won't gain much if not anything at all. You can buy a larger size and just weld on a reducer if need be.
Old Apr 21, 2005 | 09:42 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
I would ditch the stock exhaust system from the exhaust port back. Then add shorty headers (meant for a TPI car), Y-pipe, high flow cat, bigger pipes, and a good flowing muffler.
Old Apr 21, 2005 | 09:56 PM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
Actully the only thing that was planned was 14x3 open element with X stream flow top,Hooker aerochamber muffler and dynomax high flow cat.An entire exhaust from headers back is pretty pricey.
Pac J
May 17, 2020 10:44 AM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
Twinn Engines
South East Region
Sep 25, 2015 06:25 AM
