TBI ecm change
Old Apr 22, 2005 | 09:36 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
TBI ecm change
Is it possible to run the GM tbi setup with a syclone ECM. Just trying to find a factory ecm that will deal with boost and adequately run the TBI.
Old Apr 22, 2005 | 11:46 AM
BronYrAur's Avatar
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
Yeah, the 7749 ECM will run a TBI engine. Look over on the DIY-Prom board, there's a guy over there that did it and has it running. I think others have done it in the past too. It's a great option.
Old Apr 22, 2005 | 12:02 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
The only caveats are that the firing stratagy differs and the fueling stratagy with a tbi is a bit different then port injection. Nothing some tuning wouldnt fix, though.
Each tbi injector fires every time a cylinder fires (4 firings/rev). This keeps the maifold topped off with fuel. With the 749, there will be only two firings per revolution. This will cause the fueling to be a little funky. Again, I dont think itll stop it from working ok.
Old Apr 22, 2005 | 12:18 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
My intentions are to add a roots style mini-blower on to my 355.
Old Apr 22, 2005 | 01:04 PM
91RedFirebird's Avatar
Car: 91 firebird
Transmission: t-56
Umm would you need to see bost with a roots type blower? The tbi will always see vaccum and the bost is liner with rpm.
Old Apr 23, 2005 | 05:16 PM
steve8586iroc's Avatar
Your ignition curve would still need to be boost referanced.
Steve
Old Apr 23, 2005 | 11:37 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
fueling will also, you need to refrence the MAP to the manifold under the blower, you will need more fuel as the boost goes up. What you don't need is some of the REALLY big fuel adders, because you are not compensating for the loss of effective fuel pressure.
Dwayne614
Sep 28, 2015 08:33 AM
Jae992
Aug 27, 2015 09:07 AM
355tpipickup
Aug 19, 2015 10:02 PM
92camaroJoe
Aug 13, 2015 06:07 AM
