injectors...
Old Apr 30, 2005 | 10:31 PM
white91formula's Avatar
Car: 91 formula
Transmission: t5
injectors...
ok i have been told that stock lo3 injectors are way to small and arnt giving enough to the engine... is this true and where can i pick up some newer higher flow ones....
Old Apr 30, 2005 | 10:54 PM
Gaccett32's Avatar
Car: 1992 Firebird
Transmission: 4l60
Axle/Gears: 10 Bolt 3.08 Posi
http://www.turbocity.com/default.php?cPath=16_27_30
http://www.cfm-tech.com/Catalog/gm_t...5_products.htm
http://store.summitracing.com/defaul....asp&x=33&y=20
Hope these links worked its my first time. You could also look for 454 injectors in a junk yard or ebay.
The stock injectors work fine for some moderate horsepower upgrades. If you plan on going with even more power you should get your tbi bored or buy a new larger one or get a 454 tbi, to increase air flow.
Old May 1, 2005 | 01:02 PM
Benm109's Avatar
Car: 1991 Chevy Camaro
Engine: 305 TBI
Re: injectors...
Any mods to your engine? Until you add heads/cam, the stock injectors are fine.
jonnybcamaro
May 11, 2011 05:16 PM
nelapse
Oct 30, 2006 09:16 AM
bigchief
Aug 7, 2006 02:06 AM
Twilightoptics
Apr 2, 2003 10:20 PM
FiReBReTHa
Aug 21, 2001 09:23 PM
