idleing problem please help
Old May 10, 2005 | 09:23 PM
smokin91rs's Avatar
Car: 91 camaro rs
Transmission: t5
i have a 91 camaro 5spd with a mild 350 about 330hp and the car does not start and idle high then drop down like it should i have replaced the IAC and this did not help. when i start the car it will idle at about 1200rpm but after i drive it it will idle at about 2000rpm and never drop back down i am running the stock 305 chip, what could cause this it alomst seems to be working backwards, when the car was origanal it did not have this problem. for now i have it unplugged and i just have the idle set at about 900-1000rpm but i have to keep my foot on the gas when i first start it till its gets warm enoguh to idle
Old May 10, 2005 | 09:50 PM
Benm109's Avatar
Car: 1991 Chevy Camaro
Engine: 305 TBI
That's the problem right there.
You are in need of a custom PROM/chip, bad. To put it simply, the computer thinks your still running a stock 305 TBI instead of that mild 350. Tuning is the key to making power with TBI.
Check out the DIY-PROM board and start reading.
Old May 11, 2005 | 01:25 AM
Mr Badwrench's Avatar
Car: 88 RS
Engine: 2.8 untill the 3800 swap
Sounds like you have one hella a vacuum leak. What are the IAC counts, fully warmed up and in gear?
Old May 11, 2005 | 08:26 AM
smokin91rs's Avatar
Car: 91 camaro rs
Transmission: t5
guess its time for a prominator and a laptop i tryed about 3 mail order chips which all never worked and was told they most likley wouldnt, other then that the car sseems to run great but maybe i will see some more horses with some tuning thanks guys,
Old May 11, 2005 | 11:04 AM
Ronny's Avatar
Q: mild 350 about 330hp
mild?
what type of fueling? what size injectors? what FP?
Q: guess its time for a prominator and a laptop. data logging too!
Infested
May 22, 2018 11:56 PM
db057
Aug 22, 2015 08:17 PM
zeitghaist
Aug 18, 2015 07:33 AM
perZ
Aug 15, 2015 01:17 PM
