Tbi
Old May 16, 2005 | 10:35 AM
swerve's Avatar
Car: 87 z28
Transmission: 7004r
Tbi
I have a 92 camaro TBI 305, I am putting a 383 in it and keeping the computer and TBI. I will get a new chip and a bigger TBI. what is the biggest cam I can run with a computer car? Do you have any part numbers? I was told the bigget i could use is 206 int./212 exh. I cant seem to find many people who know about TBI. Thanks
Old May 16, 2005 | 10:41 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
the biggest cam isn't always the best.
I know people running solid cams in the 260* @ .050 range, with EFI cars, but I doubt that will but what will work with your combo. Before I would even guess at a cam, I would need more information about your combination, and goals for car.
Old May 16, 2005 | 11:20 AM
swerve's Avatar
Car: 87 z28
Transmission: 7004r
I have a 383 with Flat top pistons, I want to run 64cc heads but might be high compression for the tbi. At the moment i am looking a tpi system.
Old May 17, 2005 | 06:17 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Whats is your compression?
what tranny do you have (if an auto, what stall converter, and are you willing to change it.), what gear ratio, what are your goals for the car, which heads are they? what intake manifold do you have, what exaust do you have. We are going to need all the info on your car, before we can help you pick a cam.
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
Gordonr1973
Sep 29, 2015 11:59 AM
