Ram air - computer ??
Old May 18, 2005 | 01:00 AM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
If I make myself a ram air intake ... can I really expect any increase in power and gas mileage (due to better combustion) ... or .. will the computer reset by feeling more air and OVER COMPENSATING with tons of wasted fuel ?
Old May 18, 2005 | 06:13 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
I doubt you would see much change at all. if anything you will lean out a hair WOT, the WOT fueling is controlled by the chip, there is no o2 feedback. at part throttle, it figures it based on MAP and temp, then uses the o2 corrections to get it at 14.7:1. So even if it does change your part throttle at all, it would correct it back to stoich.
Old May 19, 2005 | 01:47 AM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Soooo
Can't really do anything at all ? I mean the stock airbox is uhmmmm well it brings back real bad memories from whenever I open up a hood of mostly older cars that were smogged and ya wonder where the engine gets it's air from and ya go... oh... no.. please no ... nooooo
lol
Old May 19, 2005 | 02:02 AM
BronYrAur's Avatar
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
You'll defnitely pick up some power from a setup like that or an open element, Dewey was just pointing out that the computer will not need any changes that it will compensate for any small efficiency changes that an aircleaner would make. Go for it
Old May 19, 2005 | 02:29 AM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
ok ok
*LOL* thanks
my thinking is way off right now... with me running back and forth to the damn dealership... only half of the problems are fixed so far
at least I can dump the ducttape now.. since the passenger side window motor has been properly replaced...
eightsixseven
Dec 16, 2024 01:50 PM
9192camaro
16
Feb 3, 2019 12:21 AM
stalkier
Dec 6, 2015 11:25 PM
Keith5
Aug 27, 2015 04:37 PM
bryan623
Aug 10, 2015 11:33 AM
