need some spec info
need some spec info
i got everything i want (416 heads ported,lt1 cam w/rockers,springs etc) just curious is whats the spec on the cam and rockers from the lt1? i know this isn't the best setup but from research it adds HP and isn't breaking my wallet. so i'm just curious about the specs and any WARNINGS i should watch out for would help.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Take some time to read through the stickies above. There are links that will show you the specs of LT1 cams over the years. You are going to have to do chip work if you want your combo to run like a normal engine.
Linson
Oct 1, 2015 09:50 PM
