350 block and bottom end, with 305 heads and cam what would you do
Old Jun 24, 2005 | 08:51 PM
deadhead1882's Avatar
Car: 82 El Camino
Engine: built 355
Transmission: T-56 upgraded internal
Axle/Gears: 10 bolt 3.42
exactly as the title says, need some advice, just found out that the engine has the old 305 heads and cam, engine was rebuilt around 18k miles ago.
looking for a combo that is gonna be easy to tune as i have no idea how to do it.
Should i get either an LT1 or LT4 cam, and some vortech heads or is there an easier combo to work with, or should i just junk this engine and start from scratch.
Im gonna be doing all of this on about 1500 and its gotta include a set of headers and tuning. any and all advice will be appreciated
Old Jun 24, 2005 | 09:49 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
I would stick the F/Y body LT1 cam or the standard LT4 cam into it and leave the 305 heads. Swirl ports are not that bad they will run.
Old Jun 24, 2005 | 10:48 PM
weberflorida's Avatar
Car: 1991 Camaro Z28
Fast has a good idea. I mean if you have the heads use them for now until you can afford something else. I mean those heads are not that good but it will run like fast said.
Old Jun 24, 2005 | 10:53 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Then save up get some AFRs and a single plane intake.
84z96L31vortec
Aug 20, 2017 12:16 AM
theshackle
Mar 5, 2017 06:37 PM
anesthes
Mar 10, 2016 10:35 PM
Reborn756
Sep 4, 2015 03:42 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
