A different engine swap...
Car: 94 s10, 97 s10
Engine: 383cid, 350cid
Transmission: 4L60, NV3500
Axle/Gears: 3.73, 4.10
Hey guys. This is not really a thirdgen related question, but I've received such good help here with my RS that I figured there's no better place to ask this.
Here's what I'm doing, I will try to keep this as short as possible. I have a 94 S10 pickup, 4.3 TBI. It's getting a V8... no big deal, already put a carbed 350 in my 88 S10. The actual swap is no problem, I have no questions about that. In these 4.3 TBI trucks, they use the same computer as a full size chevy truck of the same year, with a different chip. So, if you pull a 350 from a full size, drop it in the S10, put in the chip from the full size, everything works perfectly and the S10 just thinks its a full size. Same wiring harness, all accessories bolt right up.
My question is this... is a stock TBI sufficient for a stock L98 motor? I have an L98 sitting on a stand in my garage, sold the camaro it was going in. I have a TBI intake for a 350. If I bolt this intake on the L98, everything will bolt right up in my S10. So will the TBI setup starve the L98, or will it run ok? I understand that I will need to do some tuning to get the most out of it, but I first need to know if I should even bother with putting this injection on this motor. Has anyone used this combo?
Car: 1991 Chevy Camaro
Engine: 305 TBI
Yep, there are some people on here with TBI on L98s. I'm sure they can tell you more than I can, though, but I'll try.
Pretty much. The only parts you'll need are the usual 350 swap parts to make the TBI work right. 350 PROM/chip, 350 ESC module, 350 knock sensor, and 350 injectors.
It will probably run decent with the 350 chip in it, but it's just like you said, it's definitely going to need some custom tuning. But, as long as the TBI system is tuned properly, it won't starve the L98 at all. Heck, the stock TPI system starves the L98 at higher RPMs.
But, like I said, I'm sure the guys with L98s under their TBI setup can help you more than I can.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
We will pretend that you are doing a 350 TBI swap into an f-body to keep it legal.
Your swap would be no different for anyone doing a 350 TBI swap.
Benm is right on. Your biggest concern will be fueling. You won't be able to feed the motor with 4.3 or 5.0 injectors. There are a few 350 injectors you can use as well as certian big block units. For the sake of tuning and using a 350 truck prom I would stick with 350 injectors.
Your swap would be no different for anyone doing a 350 TBI swap.Benm is right on. Your biggest concern will be fueling. You won't be able to feed the motor with 4.3 or 5.0 injectors. There are a few 350 injectors you can use as well as certian big block units. For the sake of tuning and using a 350 truck prom I would stick with 350 injectors.
Car: 1991 Camaro Z28
I was told that you should get chip because the L98 engine is a lot different then then L05. I did pretty much the same swap put a L98 into my camaro and started with a 305tbi. Kept the tbi and and changed the chip, esc, and knock sensor. I was told the L98 came from the factory rated for 245hp and like 3?? ft/lbs and the LO5 was rated at 190hp and 3?? ft/lbs so there is a pretty big difference. If you call Brian at Tbichips.com he can help out with the chip if you don't have one he burnt mine and I have been nothing but happy.
Bill
Bill
Car: 94 s10, 97 s10
I can't use a chip from a thirdgen, since its a truck and uses a completely different computer. The chip I am using comes from a full size chevy truck with a 350. What are you guys referring to when you say "ESC"?
electronic spark control module... they are different between 305/350's and btw, i use 55# injectors and they work just fine... might wanna use 65's if you intend on beefing the motor up..
Car: '90 RS
Engine: 377 LSX
Bill
Bill
Car: 94 s10, 97 s10
So ESC is the same thing as the ignition module in the distributor?
I'm not going from 305 to 350, I'm going from a TBI 4.3 V6 to a TBI on an L98. I've already got the intake manifold and TBI unit off of a 1500 full size truck with a 350
Car: '90 RS
Engine: 377 LSX
Is your trans an auto or stick? If it's an auto it is probably controled by the pcm. Do pcm's have replacable chips or do you just flash program them? I don't know what year GM stopped using removeable chips and started flash programing.
Steve
Steve
Car: '90 RS
Engine: 377 LSX
Steve
Steve
Car: 1983 G20 Chevy
Transmission: 4L60
Originally posted by ShiftyCapone
Stock for Stock TPI will outperform TBI. The L98 you have now is probably around the 200hp mark as it sits. Some LO5's had the L98 cam and their heads flowed nearly identical to L98's. They were very similar motors with thier power outputs varied because of their different inductions.
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Re: A different engine swap...
84z96L31vortec
Aug 20, 2017 12:16 AM
