Code 43
Old Aug 25, 2005 | 11:36 AM
ecuxc's Avatar
Car: 1990 Camaro RS
Engine: 305 TBI
Code 43
I pull code 43 whenever I stomp the throttle. Seems that the SES light only comes on when the RPMs are above 3000. Do I need a new ESC?
Old Aug 25, 2005 | 11:46 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Its hard to say. The engine may not go into detonation when the code 43 test is run, the knock sensor may be bad, the ESC modue could certainly be bad, or the motor may be going into detonation. A scan tool would really help to point you in the right direction.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
