TBI injector spacer installation?
Old Sep 29, 2005 | 12:29 PM
szathmari's Avatar
Car: 1991 firebird
Engine: 305 TBI
Transmission: 5spd
so i bought an injector spacer from jegs and they gave some very pathetic instructions. here's the link:
http://www.jegs.com/instructions/555.../555-15410.pdf
i havent tried to install it yet because i wanted to get the run down before i would probably break something.
any advice would be greatly appreciated
-nick
Old Sep 29, 2005 | 10:34 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
uhmmm
IF you end up breaking anything .. please let me know .. because that one is one of the easiest installs you can do
Old Sep 30, 2005 | 10:38 AM
Benm109's Avatar
Car: 1991 Chevy Camaro
Engine: 305 TBI
It's really pretty straightforward. I have some good instructions laying around somewhere, but I can't find them. Anyway, here's my crack at it:
1. Remove the gas cap (relieves fuel pressure).
2. Remove the air cleaner assembly on top of the TBI unit. It's held on with 1 wing nut, 3 screws, 1 vacuum line, 1 breather tube, and 1 two-wire electrical connector (for the IAT sensor).
3. Remove the gold spacer ring from the TBI unit and disconnect the electrical connectors on the injectors.
4. Using 2 wrenches, remove the 2 fuel lines from the back of the TBI unit. Put 1 wrench on the fuel fitting nut (the ones that attach to the injector pod itself) and hold it steady. Put the other wrench on the other nut and loosen and remove it. Repeat for both fuel lines.
5. Remove the 3 torx bolts that attach the injector pod (also called fuel meter body) to the throttle body. Also remove the air cleaner stud, it just threads into the throttle body.
6. Clean and remove the old gasket material on the top of the throttle body and bottom of the injector pod.
Installation is pretty much the reverse:
7. Install the new injector spacer in between the throttle body and injector pod, and tighten the new 3 included screws down. Reinstall the air cleaner stud.
8. Reattach the fuel lines. Do this slowly. Hold the fuel line in the fuel fitting nut, and thread the nut in, making sure not to crossthread them. Once they are snug, tighten them up, again with 2 wrenches.
9. Reconnect the injector connectors. Put the gold spacer ring back on.
10. Reinstall the air cleaner housing and hook the air cleaner wing nut, screws, vacuum line, electrical connector, and breather hose back up.
11. Put the gas cap back on.
12. Your done. Test drive.
Old Sep 30, 2005 | 01:22 PM
szathmari's Avatar
Car: 1991 firebird
Engine: 305 TBI
Transmission: 5spd
thanks for the help, the instructions you gave were so much better than the ones that came with the spacer,
thanks,nick
Old Sep 30, 2005 | 03:29 PM
92camarors5spd's Avatar
Car: 1992 camaro rs
Engine: 346 ls1
Transmission: t56
Axle/Gears: strange 12 bolt 3.73's
um how much did you pay for that thing? i got mine off ebay for 6 bucks. and the instructions are the same pretty much.
Old Sep 30, 2005 | 08:52 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
The JEGs one should be like 19.95
MustangBeater20
Oct 29, 2022 09:20 PM
customblackbird
Aug 15, 2021 10:16 PM
pimp2303
Jul 27, 2017 02:03 PM
Jae992
Aug 27, 2015 09:07 AM
justin57
Aug 20, 2015 07:05 PM
