89 TBI EGR Question
Old Oct 4, 2005 | 02:08 PM
xjcamaro89's Avatar
Car: 1989 Camaro RS
Engine: 350 Holley TBI Personally Tuned
Transmission: 5 Speed
89 TBI EGR Question
Does removing all your EGR, and smog stuff help put anywhere, or does leaving it on the car keep the car running the way it should, i took everything off an had TBIchips.com make me a chip without EGR, Is this the right thing to do besides burning my own chip, or is someone with the burning capabilities willing to work with me and burn me chips till i get it right (of course Ill pay you), let me know thanks!
Old Oct 5, 2005 | 08:25 AM
Charman234581's Avatar
Car: '88 Camaro RS,
Engine: 305 TBI
Axle/Gears: Stock
If you had a chip burned then you're good to go. Better to have the EGR removed anyway.
Old Oct 5, 2005 | 12:03 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
EGR is actually a good thing. Besides visual emissions inspection reasons it does serve a valuable purpose. EGR helps reduce emissions, improves fuel economy and keeps combustion temps down. Sure it may be a little ugly, but its benifits surpass the negatives IMHO.
Old Oct 5, 2005 | 06:50 PM
flaming-ford's Avatar
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
Axle/Gears: 10 bolt 3.08 posi (4 now)
ditto to what he said.
shifty do you live in ohio? If so which of those cities would you happen to be located in (just curious). i live in Newark, i'm about an hour away from Columbus.
Old Oct 5, 2005 | 08:12 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
You have a PM
MustangBeater20
Oct 29, 2022 09:20 PM
redmaroz
Aug 16, 2015 11:40 PM
camaroken83
Aug 10, 2015 11:35 AM
