start up probs
Car: 1989 camaro rs
Engine: 305 TBI
Transmission: 700r
start up probs
well in the prev post i bumbed saying that my car wont start with out me pushing the gas , i replaced a fuse and it worked better for about 2 days , now its back to its old self , cant get enough fule to pump , i can do work on my own car but hardly have the time any more ,i so far replaced TBS (throttle body sensor) map sensor and temp sensor , and no dice the injectors are not getting enough gas into the carbs i had them cleaned and it worked a little better still takes 2 or 3 turns of the key to get it to light , so i am gonna replace my fulepump and filters , was wondering if any one thinks its the fuel pump or not before i go shelling out more cash for my car (my first car btw i worked on more then 10 types of cars tho and never had this much of a prob)
Car: Red on Red 89 RS
Engine: LO3 305 TBI
Transmission: TH-700R4
Axle/Gears: 10-bolt / 2.73
check your fuel pressure before replacing the pump, it's a major pain in the *** to swap the pump, and you dont want to do it if you dont have to
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
What is your feed line fuel pressure? Can you hear the pump prime when you turn the ignition on with the motor off? I wouldn't start replacing stuff until you do a little investigating. There aren't many sensors on these cars that are prone to failuer. Even when they do your car will typically still run.
Replacing a fuel pump isn't as bad as everyone makes it out to be. You only need simple hand tools, jack stands, jack and a few hours of your time.
84z96L31vortec
Aug 20, 2017 12:16 AM
92camaroJoe
Aug 13, 2015 06:07 AM
