New to the forum- have a few ?'s
1. i just bought my 92 rs a couple weeks ago and im just wondering what are a few mods that i can do and still have a streetable car.
2. also i plan on getting a supercharger or a turbocharger next smmer and i was just wondering which one would be better and if neither of these are possible what other solutions can i do to get the extra boost.
thanks!!!
thanks!!!
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
First, if you're serious, you need to think about the amount of cash you are dumping in to this thing to do what you want to do what you want to do. There's thousands of dollars and quite a bit of work to do to your car before it is ready for boost. Whether or not the 305 guys will admit it, it's pointless to do all of this unless you are dealing with at least a 350. And if I were you I'd be running some nice ($$$) heads and cam before I thought about boost. Factor in cost of tranny work, and rear-end work, and your budget better be big.
But for a couple of mods that are relatively cheap and easy throw on a flat bas 14x3 air cleaner assembly as well as a full exhaust system...
That would be a good start. And unless you are going to go with a carb (better then TBI IMO) or you are going to pay someone to strap your car to a dyno (preferably with a wideband) your best interest is to learn how to become a good tuner...
Car: 96 Silverado/99 Suburban
Engine: 700 cubic inches of 'Muican Awesome
Transmission: 4L80/4L60
Axle/Gears: Chunky/Clunky
Welcome to TGO!! This place is a HUGE archive of knowledge so it won't be hard for you to find the info you are looking for if you do a simple
I'm confident you'll find the info (seeing as your qestion has almost been "quote/unquote" so many times) I'm gonna close this one out. Good Luck!!
Bruce (90RS305)
I'm confident you'll find the info (seeing as your qestion has almost been "quote/unquote" so many times) I'm gonna close this one out. Good Luck!!Bruce (90RS305)
bubbaz28
Sep 18, 2015 02:09 PM
