TBI 305 to 350
TBI 305 to 350
I was shown this forum, and it seems pretty informative.. thought i'd try it out.. i have an 87 k5 blazer with a 305 tbi.. i am upgrading to a 350 that has a carb on it. What will i need to swap over to a 350? injectors, computer chip and knock sensor? where can i buy all of these? i've had a hard time finding stuff off of ebay. thanks for any help!
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Assuming you are dropping in a mild or stock LO5 (350TBI) you will need a 350 knock sensor, injectors, ESC module, wire harness, ECM, PROM and sensors. If your new 350 will have any serious mods than you will have to burn a new chip for it. A stock type LO5 can run on a carpice 350 or truck 350 PROM depending on which TBI ecm you use. The trucks and cars used different ECM's and the PROMs between them are non-compatable.
Car: ‘92 Z28
Shifty-- I have a 87 L98 short block. My dad wants to put it in an 89 RS he bought and put the RS 305 TBI system on top. Would a Caprice LO5 ECM and PROM be ok for it along with the correct sensors as long as he runs stock internals? Or should we find a truck ECM??
Car: '90 RS
Engine: 377 LSX
