350tbi injectors on a 305tbi
Car: 91 camaro rs
Engine: 305 tbi
Transmission: 700r4??
I know this has probably been asked before and i will be told to do a search but i did and i couldnt find anything..i just want to know what all it takes to put 350injectors on a 305 and is it worth it....i know i will need a fuel pressure regulator and 350tbi injectors...will i also need to get my chip re-done...any help will be nice....even if you have tips on searching the site better....thanks
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: 350tbi injectors on a 305tbi
Car: 91 camaro rs
Engine: 305 tbi
its not a stock engine...and if i go int virtualengine2000 and put it my specs it says i need injectors pushing around 60lb/hr so i think 350 will be just fine....but what all do i need to do to make 350 injectors work in my 305
Car: 1991 Camaro RS
Engine: 305 TBI
Transmission: WCT5
to make them work, you put them in the injector pod and plug them in basically
to make them work to their potential and engines potential you will have to do what shifty said
Car: 1991 Camaro RS
Engine: 305 TBI
Transmission: WCT5
havent run it... i didnt get it tuned in time for the end of the season, now its like 95% tuned and i have a couple months to get it 100% for the track... dyno in march though
Car: 91 camaro rs
Engine: 305 tbi
cool guys...thanks for the help....so if i got my chip from tbichips.com i could just tell him what im doing and he can burn me a new chip or do yall reccomend just buckling down and buying the stuff so i can do it on my own....
Car: 1991 Camaro RS
Engine: 305 TBI
Transmission: WCT5
do it yourself... youll be happy that you did in the end because you will be able to datalog and change different things until you feel the tune is 100% . by going with tbi chips or someones mail order chip you are limiting yourself toa one time tune where the tune is what they belive is correct for the car w/o the chance of future correction of the tune that isnt right for the setup IE rich lean @ WOT, or not enough timing/too little timing or a lot of different things... plus you get an understanding of how the engine reacts to different modifications
Car: '90 RS
Engine: 377 LSX
and i guess ill be needing that tuning stuff when i throw in my 383tbi too.
Car: 91 camaro rs
Engine: 305 tbi
what do yall think is a good price for tuning stuff...i know someone who will sell me everything i need to tune my car minus the laptop for 250....the software...the cable...and the burner
thejimsterz28
Sep 15, 2015 04:37 PM
