Oil Pressure sender
Old Jan 24, 2006 | 05:05 PM
Fast90Formula's Avatar
Car: 1965 Mustang
Engine: 347 stroker
Transmission: doing t-5 swap
Oil Pressure sender
Im guessing this is the sending unit above the filter.....
How do you get it out????I have broke it loose and have turned and turned and turned and it wont come out of the block am I missing something? Thanks
Oh and the whole reason its coming out is to get the last damn exhaust manifold bolt......Im not happy.....
Old Jan 24, 2006 | 08:03 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
I've never had to take the OPSU off to get the exhaust manifold bolt - I always got them from the top (on my LO3's). But it should just come out, unless it's stripped or something - it only has like 3/8 inches of threads on it.
Old Jan 24, 2006 | 11:04 PM
PhLaXuS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: 2.73 Posi w/Disc
Yep...you've got about 1/2" of really fine threads, possibly NPT. Just unscrew in the standard right-handed thread direction. Try pulling out while you unscrew it. Sounds like either the sensor's broken or the threads are stripped.
Old Jan 25, 2006 | 04:59 PM
Car: 1965 Mustang
Engine: 347 stroker
well the furthest one back wont come out I cant get the 14mm or any socket to stay on it for the way the nut is rusted I can only get a wrench on it from under neath but I have no swing due to the OPSU
Old Jan 25, 2006 | 05:45 PM
Car: 1992 RS
Engine: Carbed 350
PB Blaster is your friend - get a can and hose those stubborn nuts/bolts every day for 3-4 days - it'll come sooner or later. Skip the cheap subs - Nothing works like the PB!
Old Jan 25, 2006 | 05:46 PM
Car: 1965 Mustang
Engine: 347 stroker
haha thats funny cause I purchased a can specifically for this job...
89GTAOz
May 16, 2020 09:31 AM
Prodigious
Oct 4, 2015 11:20 PM
mddaniel
Sep 8, 2015 05:16 PM
solocus
Sep 2, 2015 12:14 PM
355sbcTPI
Aug 19, 2015 04:38 PM
