fuel tank and sending unit question for a 350 tbi swap
Old Feb 25, 2006 | 07:45 PM
dwillis's Avatar
Car: 1991 Trans Am Convertible
Axle/Gears: 3:08
I hope this is the right place to post this! i have a 92 rs lo3 and have to swap the sending unit out because of guage failure...im later on going to replace the l03 with a 350 and use my tbi setup....i have access to a plastic tank from a 2000 camaro 3.8 car will this tank fit my car and what sending unit and fuel pump should i use so i wont have to replace it later, and will the pressure regulator on my tbi work with a higher pressure pump...thanks
Old Feb 28, 2006 | 07:00 PM
dwillis's Avatar
Axle/Gears: 3:08
anyone have any input or do i need to post somewhere else
Old Mar 1, 2006 | 08:44 AM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
You should search for a ls1 tanks. I know I've seen it done before but if I remember it took some work.
EDIT:
https://www.thirdgen.org/techbb2/sho...hreadid=342745
https://www.thirdgen.org/techbb2/sho...hreadid=312886
https://www.thirdgen.org/techbb2/sho...hreadid=275567
Ghettobird52
Jul 5, 2024 11:18 PM
MustangBeater20
Oct 29, 2022 09:20 PM
theshackle
Mar 5, 2017 06:37 PM
Irocohio
Aug 12, 2015 08:03 AM
