tbi heads/intake to 1983 305
Old Mar 13, 2006 | 10:37 PM
dillardracer's Avatar
Car: 1992 rs camaro
This is probably a dumb question, but I tried doing a search and didn't find the info I need.
The LO3 in my '92 camaro has a rod knocking really bad but it still runs awesome and gets great gas mileage. I have an '83 firebird with a 305 that supposedly runs good. Can I use the firebird 305 with the tbi from my camaro?
Can I just swap intakes? Do I have to swap heads? Will centerbolt heads fit on the older v8s. What about the serpentine belt system? Anything else I should be concerned with? Would I need a different chip or something? Also, the carbed 305 came out of a 5 speed car and my camaro has an automatic.
Old Mar 13, 2006 | 10:53 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
The easiest thing to do, would be swap your 83 305 shortblock underneath the TBI heads. The early carb heads have less accessory mounting holes and your serpentine brackets will probably not bolt up (wouldn't on my van atleast), plus the intake would need the 4 bolt holes in the center around the TBI to be elongated due to the differing angles used for the corresponding years.
You will need an automatic flexplate for a 1983 chevy 305/350.
Your best bet is to ditch the 1983 305 cam, they were poorly constructed and have a habit of going flat. Trust me on that one. Go with one around 184/194 (around a stock 350) to be compatible with the TBI setups slightly hotter roller cam.
Old Mar 14, 2006 | 11:11 AM
Car: 1992 rs camaro
so the flexplate off of the '92 305 won't work then?
Old Mar 14, 2006 | 11:35 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
I'm pretty sure the flexplates are diffrent. Flywheels are diffrent between the 1 peice rear, and 2 peice rear SBC's. You can use the 83 flexplate, with your newer converter and tranny. Just use the heads from the newer car, and your accessories will work out easier. (you could drill and tap the extra hole that is needed on the older heads, but I don't suggest it.)
Old Mar 19, 2006 | 01:01 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Any pre-87 flexplate will do. Just as long as its for an engine with a 2-piece RMS.
Dwayne614
Sep 28, 2015 08:33 AM
3tas4me
Sep 4, 2015 01:45 PM
CamaroGuy350
Aug 30, 2015 02:56 PM
CamaroGuy350
Aug 26, 2015 05:11 PM
theurge
Aug 21, 2015 12:46 PM
