just curious
Old Apr 2, 2006 | 10:08 PM
TigerZ's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
just curious
im not asking for help, cause i am still reading all the threads and info about it.
but by tuning it how much power output can i be looking at? just kinda wondering the results people have gotten that have done it
i have a 91 TBI 305, headers, cat back, msd, k&n
Old Apr 2, 2006 | 10:39 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Rebuilt to stock 1984 suburban LE9 305 (180 FWHP) converted to use a 305 TBI setup on a Holley Projection manifold. Stock 5 1/2" truck air filter assembly with a K&N replacement filter. Stock sized exhaust, stock cast iron manifolds, with a high flow replacement cat, and replacement high flow/quiet muffler. This is through a 700r4/12-bolt with 3.08 gears combo. All numbers are uncorrected on a Mustang Dyno.
Stock 1992 305 Van ECM (299 AWHD BIN)
RWHP = 164.7 @ 3,850
RWTQ = 266.8 @ 2,275
Stock 1992 9C1 Caprice L03 ECM (8746 AXKS BIN)
RWHP = 152.9 @ 3,790
RWTQ = 261.7 @ 2,180
Custom Chip by ME (based on 7747 AFDY 305/700R4 VAN)
RWHP = 181.7 @ 4,900
RWTQ = 268.9 @ 2,460
The pulls were made back to back. It was driven on the dyno VERY heat soaked on a 100* Humid august afternoon, strapped down, and the first pull was made. The ECM was swapped to the Caprice and run again. The ECM was swapped on more time for a chip that I had been working on and the 3rd pull was made. The fuel injection setup/original ECM was sourced from the Caprice, so see the difference. My buddy had problems with a lack of power/throttle response/pinging with the originol setup. He then swapped it to a truck computer (Van) but it still did not please him. That is when I stepped in and tuned it. Not bad to make the engines original NET HP rating at the wheels.
Keep in mind that the old carbed truck 305s are setup different than the TBI engines. They used a hydraulic flat tappet cam sourced from the same year 350, non-swirl port 601 heads (1.84/1.50" valves, 53cc chamber), flattop pistons, and a decent factory exhaust. The calibration had the potential to be pretty far off when used with either stock ECM. The fuel pressure had been bumped to 14 psi/timing to 6* BTDC, before I ever layed my hands on it.
F-body-fan
May 4, 2026 09:42 AM
InfernalVortex
Apr 20, 2021 11:31 AM
bjpotter
Oct 4, 2015 07:48 PM
383backinblack
Sep 25, 2015 11:31 AM
F-body-fan
Sep 23, 2015 06:36 AM
