TBI retrofit
Old Apr 11, 2006 | 07:16 PM
morepower
Guest
Posts: n/a
TBI retrofit
Hello, this my first post here, I will try to keep it short. I am putting a 1987 454 tbi in my 1980 chevy truck with 4l80 tranny. I am not sure what vacuum line I need, do I need vacuum canister?
The engine will start but it is running rich, showing code 33, low vacuum. Also the engine is running hot, thermastat does not open, had 2 thermastat in, spring pointed down. Runs cool with out thermastat. I have line coming out of tb to heater core then back to radiator, is this correct?
Thanks for any help.
Old Apr 11, 2006 | 08:14 PM
r0nin89's Avatar
Car: 1987 Chevy Stepside
Engine: 350 TBI w/ a Cam
Transmission: 3 Speed Stick w/ granny low
If you have any open lines on your throttle body then connect a hose to it and cap it with a screw see if the computer responds.
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
Gordonr1973
Sep 29, 2015 11:59 AM
